New Reply
Physics : Circuts lAb kirchhoff's nodes HELP.
Share Thread Thread Tools
Feb7-11, 12:57 AM   #1
I have just done a lab and im very confused on what to do.
2 batteries 3 resistors - 3 currents -> recieved by testing.
So i have to do the theoretical equations
ive done the lab and got the currents
and so far ive came up with this.
( -V2 + Vt1 - V1 ) for the first loop
-> also (- i 2 R 2) + Vt1 + ( - i 1 R 1) idk if this is correct
and
( V3 - Vt2 + V2)
and ( i 3 r 3 ) - Vt2 + ( i 2 r 2 )
im not sure what im supposed to do. Plug in the givens?
i think i need two kirchhoff equation
1 node equation .
just very confused
Vt1 - 5v
vt2 - 4 v
R1 - 750 ohms
R2 - 100 ohms
r3 - 750 ohms
am i supposed to just find the equation? or is there a variable thats not given?
i want to LEARN how to do it so if someone could explain it would be nice
thanks in advance
2. Relevant equations
The only one i know is
V = IR
and some others for kirchhoff which i came up with going according:
1. I = current going against "Pattern" (ABCDE) = -
I = current going with the "Pattern" = +
3. The attempt at a solution
I have given this above
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb7-11, 04:11 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi alangmix! welcome to pf!
(try using the X2 icon just above the Reply box )
before i go any further, is this a letter "B", with two batteries on the left, both facing the same way, and three resistors on each of the three horizontals?
Quote by alangmix View Post
V = IR
yes, that's correct …
for that reason, the most important thing in any question on Kirchhoff's rules is to start by drawing the circuit with arrows showing the current direction, so that you don't get confused about when to use + and when to use - (it doesn't matter if you draw the arrow the wrong way … it just means that that current will come out as minus)
i've never seen that notation before (what does the "t" stand for?), but i see what i means, and yes it's perfectly correct
and
( V3 - Vt2 + V2)
you may have got the sign of i2R2 wrong, but i can't tell without knowing whether the two batteries are pointing the same way or not
and anyway these should be equations, so they must end "= 0"
1 node equation .
(btw, they're all Kirchhoff equations … KVL and KCL, or loop and node )
yes, those are your two loop equations, and you need a node equation also, only involving the currents …
then you can happily plug and chug
Feb8-11, 02:00 PM   #3
thanks for the help and
the circuit is like this
_______resistor 1 ___________l___ _______resistor 3 _____________
l l
Battery 1 -------------------- resistor 2 -------------------------battery 2
l l
l______________-_________________l_________-________________l
current for both batteries going upward hence- creating two loops.
did i get what i wrote correct?
what else am i missing ?
Feb8-11, 02:08 PM   #4
Recognitions:
hi alangmix!
sorry, but i don't understand your diagram
can you just describe the circuit in detail?
Feb8-11, 09:05 PM   #5
It goes from battery one to resistor 1 -> while the other battery on the other side attaches its self to resistor 3 and in the middle is resistor 2. ABCDEF as the whole circuit.
Edit :
B -> is not the battery. just simply the format of the circuit board
on the first post. the T stands for Voltage Total. for battery 1 and battery 2
Feb10-11, 01:20 PM   #6
Recognitions:
Try drawing your ascii circuit diagram using an editor with a fixed width font (for example, use Notepad and a Courier font), then copy and paste it into a CODE block in a Physics Forum reply. A CODE block is like a QUOTE block, only use the word CODE instead of QUOTE in the tags. The formatting shouldn't be messed with inside such a block. For example:
Code:
     +---R1----+-----R2----+
    --- V1     R3      V2 ---
New Reply
Tags
kirchhoff's laws
Thread Tools
Similar Threads for: Physics : Circuts lAb kirchhoff's nodes HELP.
Thread Forum Replies
Need help on series circuts Introductory Physics Homework 3
Pressure nodes and displacement nodes Classical Physics 0
Help with electrical circuts Engineering, Comp Sci, & Technology Homework 0
circuts Introductory Physics Homework 1
circuts Introductory Physics Homework 7
