Electric Forces between charges
The discussion focuses on calculating the magnitude of the electric force between two charged pith balls, each with a mass of 0.100 g and an unknown charge magnitude q. The relevant formula used is Coulomb's Law, F = k (q x q/r²), where k is the electrostatic constant. The equilibrium of forces is analyzed, indicating that the vertical component of tension balances the weight, while the horizontal component balances the electric force, allowing for the determination of charge q.
  • Coulomb's Law for electric forces
  • Basic principles of equilibrium in physics
  • Understanding of tension in strings
  • Knowledge of trigonometric functions for angle calculations
  • Study the derivation and applications of Coulomb's Law
  • Explore the concept of electric field strength and its calculations
  • Learn about the principles of static equilibrium in physics
  • Investigate the role of tension in systems involving angles and forces
Physics students, educators, and anyone interested in understanding electric forces and equilibrium in charged systems.
thst1003
Hanging from threads are two charged balls made of pith (a very light, spongy material that comes from inside the stems of certain plants). The balls each have a mass of 0.100 g and a charge of the same magnitude q and are attracted toward each other, as shown in the figure below. (Take θ = 18.9° and r = 1.82 cm.)
Question: What is the magnitude of the electric force?
F = k (q x q/r^2)
Please Help. I could not figure out how to solve without q.
use the equilibrium for on charge ...
ie .. vertical component of tension balances weight and horizontal balances electric force
you'll get charge ...
  • · Replies 16 ·
