Characteristic Polynomial of Matrix
The discussion revolves around finding the minimal polynomial and characteristic polynomial of the matrix J, which is defined as an nxn matrix with all entries equal to 1. Participants are exploring the eigenvalues associated with this matrix.
  • The original poster attempts to compute the characteristic equation by calculating the determinant of (J - λI) and discusses the implications of using Leibniz's formula. They express uncertainty about the presence of terms in the determinant expansion and seek alternative methods.
  • Some participants suggest manipulating the matrix by subtracting rows to simplify the determinant calculation, while others question the correctness of the resulting characteristic equation and the expected coefficients.
  • There are discussions about the implications of specific cases, such as n = 3, and the challenges of generalizing results for all n.
  • Suggestions of using induction to prove results are also raised, indicating a search for a more robust approach.
The discussion is ongoing, with participants providing hints and alternative perspectives. There is no explicit consensus on the best method to proceed, but several productive lines of inquiry are being explored, including matrix manipulation and the use of induction.
Participants are working under the constraints of homework rules, which may limit the types of guidance they can provide. There is an acknowledgment of the complexity involved in proving results for the general case of n.
iamalexalright
Let J be the nxn matrix all of whose entries are equal to 1. Find the minimal polynomial and characteristic polynomial of J and the eigenvalues.
Well, I figure the way I'm trying to do it is more involved then other methods but this is the easiest method for me to start with.
We can find the characteristic equation of J (and thus the eigenvalues) by computing:
[tex]det(J - \lambda I)[/tex]
We also know that the determinant of a nxn matrix can be found by computing:
[tex]det(A) = \sum_{\sigma \in S_{n}} sgn(\sigma) \prod_{i = 1}^{n}A_{i,\sigma_{i}}[/tex]
where S_n is the set of all permutations of (1,2,3,...n). sgn is the signature of the permutation.
Now we want to compute [tex]det(J - \lambda I)[/tex]
I know there will be n! terms after applying Leibniz's formula, half of which will have a positive signature and half that will have an odd signature.
Now, I don't really know how to prove this but with some investigation we can see that there will only be one term with degree n, ie:
[tex]det(J - \lambda I) = (1 - \lambda)^{n} + ...[/tex]
There shouldn't be any terms with degree n - 1...
I'm not sure where to go after this... I realize that this probably isn't the best method to go about this (it's late and I've been working on homework for awhile now...) so any other suggestions would be great (along with suggestions on how to continue with this path if possible).
hi iamalexalright! :smile:
(have a lambda: λ :wink:)
hint: subtract the first row from the other rows :wink:
Hrmph, could have sworn I thought of that...
so then we are left with a new J with all 1's in the first row and 0's everywhere else
the determinant of this new matrix would then be (since only diagonal terms contribute):
[tex](-1)^{n + 1}(1 - \lambda)\lambda^{n - 1}[/tex]
Here is my issue... that is the charecteristic equation for the new matrix but there should be a coefficient of n on the smaller degree:
example: n = 3
the formula above gives:
[tex]-x^{3} + x^{2}[/tex]
but I should have:
[tex]-x^{3} + 3x^{2}[/tex]
Don't know how to resolve that.
Also, if n = 3 would the minimal polynomial be:
x(3 - x) = 3x - x²
no, you need to do it for J - λI :redface:
Okay, so that will leave me with a matrix that has:
(1 - λ) in the first diagonal position
-λ for all other diagonals
1's in the rest of the first row
λ's in the rest of the first column
zero's elsewhere
Not sure where to go from here... I can see with small examples that it works out but proving for all n seems tricky for me.
have you tried induction?
Check out Avodyne's reply in this (https://www.physicsforums.com/showthread.php?t=314070&page=3) thread for another way to pursue this. You can check to see that J2 = nJ, which imposes a condition on the possible values for J's eigenvalues. Then look at the trace tr(J) to find the multiplicity of each of these values.
  • · Replies 19 ·
