| New Reply |
why do maximum L/D and max. lift not occur at the same angle of attack? |
Share Thread | Thread Tools |
| Feb8-11, 05:45 AM | #1 |
Hello,
I did a wind tunnel test with a NACA 0012 airfoil. And my results showed that the highest lift-to-drag ratio occurred at an angle of 12degrees where as my maximum lift is at 15degrees. I even read somewhere that these values do differ but there was no such explanation as in why is that so.. Can someone please help me out.. Thanks |
| Feb8-11, 06:07 AM | #2 |
Can't really word it better than the wiki entry so here it is:
| Feb8-11, 06:41 AM | #3 |
That is a very good question,
We actually try to calculate maximum lift of the aircraft or aerofoil to know the maximum lift is how far and the next point of the increase in the Angle of attack (AOA) causes downfall of the lift and increase in drag and tends to stall. And when coming to L/D ratio or gliding ratio we take into account of the lift how many times greater than and this ratio is important for a stable flight and ideal performance. For example: in emergency landing the aircraft has to land quickly and we have a problem of insufficient fuel if L/D ratio is 12 at for ‘X’ AOA then the pilot tries to get the aircraft to that point or at particular AOA so that he can save some fuel for emergency landing and he knows that lift is 12 times greater than drag and pilot knows what to do. |
| Feb8-11, 07:00 AM | #4 |
why do maximum L/D and max. lift not occur at the same angle of attack?Here goes for my attempt at an explanation: The optimum L/D ratio is the point where you get the most lift possible with as little drag as possible. Above this point, you may get more lift but you get significantly more drag. Below this point, you may have significantly less drag but you don't have much lift. In your example, your optimum L/D ratio may be 10 (Lift=20/Drag=2) but your maximum lift L/D ratio could be 5 (Lift=25/Drag=5)*. Although in the latter case you are getting more lift than the previous, you are also getting significantly more drag. Making the AoA less efficient to use. * Numbers purely for demonstration. |
| Feb8-11, 07:22 AM | #5 |
Thanks, it really helped :)
| New Reply |
| Thread Tools | |
Similar Threads for: why do maximum L/D and max. lift not occur at the same angle of attack?
| Angle of Attack Indicator | Aerospace Engineering | 14 | ||
| The angle of attack in glide- how high can it be? | Mechanical Engineering | 1 | ||
| how to find the angle of attack? | Introductory Physics Homework | 1 | ||
| Angle of attack | Introductory Physics Homework | 1 | ||
| maximun lift & maximum L/D | Aerospace Engineering | 1 | ||
