What Equations Calculate Tangential Acceleration Correctly?
  • Thread starter Thread starter pennyfx
    Circular Rotation
The discussion clarifies the calculation of tangential acceleration using two equations: At = w*r and At = dv/dt. For a disk with a radius of 0.12 m accelerating from rest at 8 rad/s², the angular velocity at t = 5s is 40 rad/s, leading to a tangential acceleration of 0.96 m/s² using At = w*r. Both equations are valid but serve different purposes; At = w*r calculates instantaneous tangential acceleration, while At = dv/dt determines average tangential acceleration over time.
  • Understanding of angular velocity and acceleration
  • Familiarity with the equations of motion in rotational dynamics
  • Basic knowledge of calculus, specifically derivatives
  • Concept of tangential and centripetal acceleration
  • Study the relationship between linear and angular motion in physics
  • Learn about the implications of constant radius in rotational dynamics
  • Explore the derivation and applications of the equation At = dv/dt
  • Investigate real-world examples of tangential acceleration in mechanical systems
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the principles of rotational motion and tangential acceleration calculations.
pennyfx
A disk of radius .12 m starts accelerating from rest at 8 rad/s^2 At t = 5s
A)What is the Angular Velocity
This one is easy.. Av = 8rad/s^2*5 = 40 rad/s
And makes sense.
B)What is the tangential Accel?The book gave answer of .96 m/s^s Therefor, i assumed that the equation is At = w*r w=omega which is 8 rad/s^2 * .12m = .96 m/s^2
However, later I found an equation for At given as At=dv/dt
What gives? Which equation is correct for Tangential Accel? If they are both correct then how would I use At=dv/dt?
Thanks
Both are correct,
Remember dv/dt is nothing but d(r*Av)/dt and since r is constant r*d(Av)/dt
which is nothing but r*w... which was the first equation you used...
for your question! Both equations for tangential acceleration are correct, but they are solving for different things. The equation At = w*r is solving for the tangential acceleration at a specific point in time, while the equation At = dv/dt is solving for the change in tangential velocity over time.
In this specific scenario, the tangential acceleration at t = 5s is 0.96 m/s^2, as calculated using At = w*r. This tells us how much the tangential velocity is changing at that specific moment in time.
On the other hand, if we were to use At = dv/dt, we would be solving for the average tangential acceleration over a period of time. This equation takes into account the change in tangential velocity over that time period, rather than just at a specific moment.
Both equations are correct and can be used depending on what information you are trying to find. If you are trying to find the tangential acceleration at a specific moment in time, use At = w*r. If you are trying to find the average tangential acceleration over a period of time, use At = dv/dt.
  • · Replies 17 ·
