What is the Probability of Total Spin in a Two Particle System?
The discussion revolves around a two-particle system characterized by their spins, focusing on calculating the probability of the total spin when particles are taken from different sources. The participants explore the implications of polarization on the problem and the mathematical framework involving Clebsch-Gordan coefficients.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the construction of wavefunctions and the role of polarization in determining probabilities. Questions arise about the calculation of Clebsch-Gordan coefficients without specific spin values and the nature of unpolarized states as linear combinations of spin states.
The conversation is ongoing, with participants providing insights into the mathematical aspects of the problem. Some guidance has been offered regarding the relationship between the states and the coefficients, but explicit calculations or examples have not been fully developed.
There is mention of constraints related to the lack of specified spin values for the particles and the challenge of finding relevant information in existing resources. The nature of unpolarized states and their representation in the context of the problem is also under discussion.
kreil
Insights Author
Consider a two particle system of which one particle has spin s1 and the other s2.
1. If one particle is taken from each of two sources characterized by the state vectors |s1,m1> and |s2,m2> respectively, what is the probability that the resultant two particle system will have total spin S?
2. If the particles are taken from unpolarized sources, what is the probability that the two particle system will have total spin S?
[tex]S^2|s_n,m_n \rangle = \hbar^2 s_n(s_n+1)|s_n,m_n \rangle[/tex]
I need help getting started, and also I don't understand how polarization affects the nature of the problem in part 2. To calculate the probabilities don't I just construct a wavefunction for the particle in that spin state and square it? If so what goes in the bra?
[tex]| \langle \psi | s_1,s_2,m_1,m_2 \rangle |^2[/tex]
Edit: I think this is a good start:
[tex]\langle \hat S \rangle = \langle \psi|\hat S|\psi \rangle = \Sigma \langle \psi | \hat S |s_1, s_2,m_1,m_2\rangle \langle s_1, s_2,m_1,m_2|\psi \rangle[/tex]
[tex]= \hbar^2 \left [ s_1(s_1+1)+s_2(s_2+1) \right ] \Sigma |\langle s_1, s_2,m_1,m_2|\psi \rangle|^2[/tex]
But how do I quantify the squared wavefunction on the RHS? Should I simple solve for it and say that is the probability?
For part 1, the states of total spin [tex]S[/tex] are the states [tex]|S,m_S\rangle[/tex]. Note that [tex]m_S[/tex] is not specified. The overlap with the states [tex]| s_1,s_2,m_1,m_2 \rangle[/tex] are the Clebsch-Gordan coefficients.
For part 2, the unpolarized states are linear combinations of [tex]|s,m_s\rangle[/tex].
Is it possible to calculate the CB coefficients without specifying a spin value for each particle?
No, you're probably not going to get explicit numbers in this problem. It's mainly about finding the proper linear combinations.
I'm having trouble with part 2, and I can't find much information about the situation in my notes or book (Ballentine). Can you expand a little bit more on this? Perhaps an example from a similar problem?
instead of [tex]\left| s_1 , m_1 \right\rangle \otimes \left| s_2 , m_2 \right\rangle[/tex] forming up the composite system
you have
[tex]( \alpha \left| s_1 , m_1 \right\rangle + \alpha' \left| s_2 , m_2 \right\rangle) \otimes ( \alpha \left| s_1 , m_1 \right\rangle + \alpha' \left| s_2 , m_2 \right\rangle)[/tex]
so you get a mixture of [tex]s_1+s_2, 2s_1, 2s_2[/tex] states
  • · Replies 0 ·
  • · Replies 20 ·
