Where Can I Find a Connector for a 40kv 15ma High Voltage Power Supply?
The discussion revolves around finding a suitable connector for a high voltage power supply with a specification of 40kv and 15ma. Participants explore the availability of connectors, their standards, and the necessary precautions when dealing with high voltage applications.
  • One participant inquires about the standardization of connectors for high voltage applications, suggesting uncertainty about their availability.
  • Another participant notes that connectors can vary widely and questions whether local high voltage stores exist or if online ordering is necessary.
  • A suggestion is made to look at a specific website for images of coaxial plugs to identify the needed connector.
  • A participant shares their limited experience with high voltage, indicating that connectors are often not like standard coax connectors and require special handling and materials.
  • Concerns are raised about safety, including the risks of electrocution and the importance of using appropriate connectors and maintaining cleanliness to prevent arcing.
  • There is a suggestion that having a parts list could assist in finding the correct connector, and trying out different options might be beneficial if an assortment is available.
Participants express uncertainty about the standardization of high voltage connectors, indicating that multiple views exist regarding their availability and safety considerations. The discussion remains unresolved regarding the best approach to find the appropriate connector.
Participants mention the need for special connectors and precautions when working with high voltage, highlighting the potential dangers involved. There is also a reference to the variability of connectors and the importance of specific handling practices.
Drakkith
Mentor
Hey all, I've got a high voltage power supply that I need some sort of connector for. It's a 40kv 15ma output and the connector screws in over a hole that leads to an enclosed plastic tube with a metal rod about halfway down. Are these standard connectors or do i need to do something crazy to get one?
standard? best i can remember, they are all over the place.
I havn't dealt with high voltage before. What do you mean by all over the place? Should there be a high voltage store somewhere around town I can go to? Or do I need to order online?
yeah, i mean like there's all kinds. http://www.tycoelectronics.com/catalog/menu/en/12153
i haven't done a lot of HV work, just built a precision voltage divider for HV test set a few years back. honestly, it is a bit of a pain in the arse. most of the connectors aren't like those coax connectors above at all. typically, they're plastic. you've got to use special connectors, special wire, and keep everything clean. no sharp edges on any conductors, etc. what you've got will arc and is more than enough to kill you, so you'll need to be very careful with it. we had one tech at the time that did get electrocuted, and he was rather upset about it for a while. stuff leaks, so try not to get killed.
anyhoo, not sure the best way. it would help if you had a parts list and could track it down that way. if you had access to an assortment, you could just try out different ones maybe. all ours was MIL, so it wasn't really a problem finding exact matches. usually.
Awesome! Thanks guys!
  • · Replies 16 ·
