De Broglie Waves: Questioning Accuracy?
  • Thread starter Thread starter CollectiveRocker
    De broglie Waves
The discussion focuses on the accuracy of non-relativistic calculations of the de Broglie wavelength for a 100-keV electron. The de Broglie wavelength is calculated using the formula λ = h/p, where h is Planck's constant and p is the momentum, defined as p = mv in non-relativistic terms. While non-relativistic calculations yield negligible errors at low speeds, they become less accurate as particle speeds approach the speed of light. For a 100-keV electron, the percentage error in the de Broglie wavelength is minimal, but relativistic calculations are necessary for higher energy particles to ensure precision.
  • Understanding of de Broglie wavelength and its formula λ = h/p
  • Familiarity with momentum calculation p = mv in non-relativistic physics
  • Basic knowledge of special relativity and its implications on particle physics
  • Concept of energy levels in particles, specifically electron energy in keV
  • Study the implications of special relativity on particle momentum calculations
  • Explore relativistic equations for calculating de Broglie wavelength
  • Investigate the behavior of particles at high energies, particularly above 100 keV
  • Learn about Planck's constant and its role in quantum mechanics
Physicists, students of quantum mechanics, and anyone interested in the calculations of particle behavior at various energy levels.
CollectiveRocker
A Question of De Broglie Waves?
The problem states: By what percentage willl a non-relativistic calculation of the de Broglie wavelength of a 100-keV electron be in error?
What have you done so far?
The de Broglie wavelength of a particle is given by the equation λ = h/p, where h is Planck's constant and p is the momentum of the particle. In non-relativistic calculations, the momentum of a particle is given by p = mv, where m is the mass of the particle and v is its velocity.
To calculate the percentage error in the de Broglie wavelength, we need to compare the non-relativistic calculation with the relativistic calculation, which takes into account the effects of special relativity at high speeds.
At low speeds, the non-relativistic calculation is accurate and the percentage error is negligible. However, as the speed of the particle approaches the speed of light, the relativistic effects become significant and the non-relativistic calculation starts to deviate from the actual value.
In the case of a 100-keV electron, the speed is relatively low and the percentage error in the de Broglie wavelength would be very small. It is only at much higher energies, close to the speed of light, that the relativistic effects become significant and the non-relativistic calculation would result in a larger percentage error.
Therefore, while the non-relativistic calculation of the de Broglie wavelength may not be completely accurate, it is still a useful approximation for particles with low energies. For higher energy particles, a relativistic calculation would be more accurate. Overall, the accuracy of the de Broglie wavelength calculation depends on the energy and speed of the particle, and it is important to take into account the effects of special relativity at high energies.
9K
