Archimedes' Problem: Iron Body Submerged in Water
  • Thread starter Thread starter germangb
    Archimedes
The discussion centers on calculating the buoyant force and apparent weight of an iron body submerged in water. The iron body has a density of 7800 kg/m³ and a weight of 0.13 N in air. The correct volume of the iron body is calculated using the formula Volume = Weight in air / (g * Density), resulting in approximately 1.699 x 10^-6 m³. The buoyant force is then calculated as 0.1133 N, leading to an apparent weight of -1.47 N when submerged, indicating an error in the initial calculations presented.
  • Understanding of buoyancy principles and Archimedes' principle
  • Basic knowledge of density calculations
  • Familiarity with gravitational force (g = 9.81 m/s²)
  • Ability to perform unit conversions and dimensional analysis
  • Study Archimedes' principle in detail
  • Learn about buoyant force calculations in fluids
  • Explore density and its applications in physics
  • Practice problems involving submerged objects and apparent weight
Students in physics, engineers working with fluid dynamics, and anyone interested in understanding buoyancy and density calculations in real-world applications.
germangb
i have the following problem:
-an iron (7800kg/m3) body is submerged into in water (density = 1000kg/m3)
his weight in the air is 0,13N.
what i did is:
E=dVg (Push force, density of the liquid, volume of the body sumerged and gravity, respectively)
then:
the volume of the iron body is 0,000633m3, then:
E = 1000*0,000633g = 1,60
so, the the apparent weight is 0,13-1,60= -1,47N
______________________________
did I do it right?
how did you get volume of iron body as that? and how do you get 1000*0.000633*g = 1.60??
find volume correctly first. see that actual weight is 0.13N, therefore m = 0.13/g Kg. use density to find volume.
tell us what you get.
what i did is:
then:
did I do it right?
Use basic definition for density.
Volume(iron) = .13/(g*density)=1.699x10^-6 m3
Weight of iron in water = (weight in air) - dVg = .1133N
I'm open for correction.
  • · Replies 25 ·
12K
