How can I initialize private members in a class using client code?
  • Thread starter Thread starter Jim Roberts
    Members
The discussion revolves around how to initialize or set the values of private members in a class using client code, specifically focusing on different programming languages, including Java and C++.
  • One participant, Jim, inquires about initializing private members of a class from client code.
  • Another participant suggests using setter methods as a solution, providing a Java example of a class with private members and corresponding getter and setter methods.
  • A later participant, Hurkyl, asks for guidance on how to achieve similar functionality in C++, specifically how to initialize or change private member variables in the main function.
  • A subsequent reply provides a C++ code snippet demonstrating the use of a setter method to set a private variable and retrieve its value.
Participants generally agree on the use of setter methods as a means to access and modify private members, but there is a lack of consensus on the specific implementation details across different programming languages.
The discussion does not address potential limitations or assumptions regarding the use of setter methods in different contexts or languages.
Jim Roberts
I have a class and i'd like to initialize
or set the values of its private members
in the client code, how can I do that ?
thanku,
jim
Computer science news on Phys.org
Through setter methods.
For example, in Java style:
Code:
public class Example {
  private int var;
  public int getVar() { return var; }
  public void setVar(int i) { var = i; }
:wink:, but can you tell me how to do that in c++?
and initialize/change the values of class's private
member variables in main function ?
thanks hurkyl
Code:
int main(int argc, char *argv[]) {
Example exmpl;
exmpl.setVar(2004);
printf("private var = %d\n", exmpl.getVar());
return 0;
  • · Replies 34 ·
11K
  • · Replies 39 ·
