Finding Tension in Elevator Acceleration: Physics Problem Help
  • Thread starter Thread starter JeffC
The discussion revolves around a physics problem involving an elevator's upward acceleration and the tension in a cord holding a bundle. The scenario includes a passenger in the elevator and requires understanding of forces acting on the bundle due to gravity and the elevator's acceleration.
  • Participants explore the calculation of the elevator's acceleration and the application of Newton's Second Law to determine the tension in the cord. There is a suggestion to use kinematic equations to find the acceleration.
Some participants have provided guidance on potential methods to approach the problem, including the use of kinematic equations and force analysis. Multiple approaches are being discussed, with one participant indicating a preference for a specific method they found effective.
The original poster expresses uncertainty about where to start and seeks initial guidance. The problem includes specific values such as the mass of the bundle and the acceleration due to gravity, which are relevant to the calculations but not fully explored in the discussion.
JeffC
I was doing my homework for my physics class, but now I am stuck at two questions and don't know what to do. :( And I don't know where to start. If someone can get me started and little tips on how-to-solve this question, that'd be awesome! :D
If someone can help me solve this problem, I'd be really greatful! :) And I am glad that I found such a wonderful forum.
Thank you. :)
An elevator starts from rest with a constant upward acceleration and moves 1min the first 1.9 s. A passenger in the elevator is holding a 4.4 kg bundle at the end of a vertical cord. The acceleration of gravity is 9.8 m=s2 :What is the tension in the cord as the elevator accelerates? Answer in units of N.
Can you figure out how fast the elevator is accelerating?
Use
[tex]s=ut+\frac{1}{2}at^2[/tex] to find the constant upward acceleration,a.
Use Newton's 2nd Law to find the tension :
T-mg=ma
T=m(a+g)
Upward direction is choosen to be positive, downward direction to be negative.
Thank you both of you for answering the question. :)
I actually tried couple of approaches and I discovered Leong's method is the best one and did it. :)
Thanks again for the help!
  • · Replies 31 ·
  • · Replies 25 ·
