How Do You Determine Electric Fields and Forces Between Charges?
  • Thread starter Thread starter derekbeau
    Charges
The discussion revolves around determining electric fields and forces between point charges, specifically focusing on two questions involving the calculation of electric fields at a point due to multiple charges and the comparison of electric and gravitational forces between protons.
  • The original poster attempts to calculate the electric field at the origin due to two point charges and seeks clarification on the correct approach. They also attempt to calculate the electric and gravitational forces between two protons and express uncertainty about their calculations and formatting the answer.
Some participants provide guidance on calculating the net electric field from the two charges and suggest considering the distances involved. Others confirm the original poster's approach to calculating forces and suggest how to express the ratio of the forces. The discussion reflects a mix of exploration and clarification without reaching a definitive conclusion.
The original poster expresses a need for thorough explanations and indicates that they have completed other questions, suggesting a focus on these specific problems. There is mention of potential confusion regarding the calculations and formatting of answers.
derekbeau
I have two questions I am having trouble with, if you could please help me that would be great.
Two point charges, q1 = 4.0×10^6 C and q2 = -1.0×10^6 C, are located on the x-axis at x1 = -1.0 cm and x2 = 3.0 cm
Determine the electric field at the origin
I have no idea how to do this
Two protons are separated by a distance of 1.0×10^10 m (roughly the diameter of an atom). Calculate the electric force and gravitational force on one proton due to the other proton. The electric force is much larger. What is the ratio of the electric force to the gravitational force?
I thought id find the electric force by:
F = [k(1.6 x 10^-19)(1.6 x 10^-19)] / (10^-20) = 2.304 x 10^-8
And find the gravitational force by:
F = [(g m1 m2) / (10^-20)] = 2/742 x 10^-33
I don't know if those are right, but even if they are i don't know how to format the answer
I just need some thorough explanation on these two questions, i got all my other ones done.
Thanks
Q1
Because you were given that both point charges are along the x-axis essentially you are just being asked to find the net electric field resulting from the two point charges. Using your equation for the electric field you should be able to find the field for each point and from this the net field. Remember that the distance to the origin is not the same for both charges.
Q2
It's been a while but I believe you are right on. You calculated the electric and gravitational forces and indeed the electric force should be considerably stronger.
When setting up a ratio of the two forces it would be better to write it in the form Fe/Fg or Fg/Fe. Either way you will get the ratio of one force to the other.
ok for Q1 i did
F = kQ / d^2 = [k(4 x 10^ -6)] / 1
F = kQ / d^2 = [k(-1 x 10^-6)] / 9
Then i added these two together but didnt get the correct answer
nvm i got them
11K
