New Reply
Relating Radial Strain to Circumferential
Share Thread
Feb12-11, 12:10 PM   #1
Hi,
I have a solid cylinder to which I have strain gauges attached to measure axial and circumferential strains. My goal is to relate the circumferential strain to radial strain and then to calculate possion's ratio. Every time I try to work out the geometry of the problem I end up saying that circumferential strain is equal to axial strain, can this be true?
Terms:
Ec = Circumferential Strain = dC/C
dC = change in length of circumference
C = circumference
Er = Radial Strain = dR/R
dR = change in length of radius
R = radius
Here is my logic:
Strain Circumferential (Ec) is equal to the strain is see in one single strain gauge attached along circumference. dC = 2*PI*dR. Then dR can be expressed as dR = C*Ec/(2*PI). Which means Er= dR/R = C*Ec/(2*PI*R) = Ec. Can that be right?
Then is my possion's ratio radial/axial or axial/radial?
Thanks.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Feb14-11, 08:12 AM   #2
You're right about the radial strain being equal to the circumferential strain. Since circumference changes proportionally with radius, the strains will be the same since strain is really just a proportion.
However, you're not taking axial strain into consideration. Your axial strain will be dL/L. The Poisson's ratio is v=-Er/Ea = -(dR/R)/(dL/L) or -(dC/C)/(dL/L) if you prefer.
New Reply
Similar discussions for: Relating Radial Strain to Circumferential
Thread Forum Replies
Motion in curves - Find radial and circumferential components of V and A Calculus & Beyond Homework 4
Where to place strain gauges to measure shear strain on a continuous supported beam Mechanical Engineering 0
radial arms of the SBa, Sbb and Sbc galaxies - why are they radial? Astrophysics 0
strain, thermal strain and agle of twist Engineering, Comp Sci, & Technology Homework 0
what's the physical meaning of true shear strain and simple shear strain Atomic, Solid State, Comp. Physics 2
