When to use string classes in C#?
  • Context: C#
  • Thread starter Thread starter mcodesmart
    Classes String
The discussion centers on the use of mutable and immutable string classes in C#. Immutable string classes are preferred for efficiency as they can share storage for identical objects, reducing overhead from temporary object creation. The StringBuilder class is recommended for scenarios involving extensive string concatenation, as it pre-allocates a large array to hold characters, minimizing repeated memory allocation. Developers should utilize mutable strings only when the string's content is expected to change after creation.
  • Understanding of C# string classes
  • Knowledge of object-oriented programming principles
  • Familiarity with memory management in programming
  • Experience with performance optimization techniques
  • Research the performance implications of using C# StringBuilder for string manipulation
  • Explore the differences between mutable and immutable data structures in C#
  • Learn about memory allocation strategies in C#
  • Investigate best practices for optimizing string operations in C# applications
Software developers, particularly those working with C#, and anyone interested in optimizing string handling and memory management in their applications.
mcodesmart
We have a string builder class which is mutable in C#. Why do we need immutable string classes?
Technology news on Phys.org
Basically, for efficiency. for example the immutable classes can share storage for identical objects. Harmless-looking statements in an object oriented language can often create and destroy temporary objects, and the overheads are much smaller if the contents of these are known to be immutable.
You should only use mutable strings if you know the contents of the string may change after you have created it.
A StringBuilder class just pre-allocates a big array to hold the characters of a string you are yet to create. It prevents the need to call the allocator over and over again if concatenating a bunch of (immutable) shorter strings.
When there is a LOT of string concatenation going on at runtime, it is often more efficient (significantly more) to use StringBuilder.
  • · Replies 34 ·
  • · Replies 47 ·
  • · Replies 22 ·
