How can I solve this Mechanics problem, about a cylinder in water?
The discussion focuses on solving a mechanics problem involving a cylindrical submarine with a radius of 3.2 m, a length of 35 m, and a total mass of 1.2×10^6 kg. The buoyancy force, B, is defined as B =(1020 + 0.25z)Vg, where z is the depth, V is the volume, and g is the acceleration due to gravity (9.8 m/s^2). Participants explore the maximum downward velocity of the submarine and the additional depth it will sink after jettisoning ballast at 250 m. Key equations include the volume of a cylinder (V = πr²L) and the relationship between buoyancy and acceleration.
  • Understanding of buoyancy principles and forces
  • Familiarity with basic mechanics equations, specifically F=ma
  • Knowledge of volume calculations for geometric shapes, particularly cylinders
  • Basic grasp of kinematic equations for motion analysis
  • Calculate the volume of the submarine using the formula V = πr²L
  • Explore the relationship between buoyancy and acceleration in fluid dynamics
  • Investigate the effects of jettisoning ballast on submarine dynamics
  • Learn about kinematic equations and their application in vertical motion problems
Students studying mechanics, engineers working on underwater vehicles, and anyone interested in fluid dynamics and buoyancy calculations.
aero&astro
1. A cylindrical submarine has a radius R of 3.2 m, a length L of 35 m and a total mass of 1.2×10^6
kg, of which 1×10^5 kg is ballast that can be jettisoned. The total upwards buoyancy force, B (N), is regulated as a function of depth and is given by
B =(1020 + 0.25z)Vg ,
where z is the depth from the water surface to the top of the submarine (m), V is the volume of the submarine (m^3) and g is the acceleration due to gravity (9.8 m/s^2).
(i) Neglecting viscous drag find the maximum downward velocity of the submarine assuming it
descends from a stationary position just below the water surface. The volume remains constant.
(ii) If the captain decides to drop the ballast at a depth z = 250 m, how much deeper (than 250 m) will the submarine sink?
this is all assuming the submarine is shaped like a simple cylinder. Can you help me?
2. Homework Equations the one given and F=ma is all that i can think of
well, we need to know the volume of the submarine. so the equation for the volume of a cylinder is helpful...
probably: pi*r^2*L...
I'm not sure, but does the equation for B give us an acceleration? I don't think anything cancels out the /s^2 part of gravity so i think we get an acceleration for B.
isn't there an equation something like V = 1/2acceleration^2 + V(0)... If we plug our result for B into this... I think there's a (t) in the equation above. don't know exactly where this is going.
well... just some thoughts...
  • · Replies 49 ·
