How Do You Calculate Energy Harvested from a Shaken Electromagnet Device?
The discussion focuses on calculating the energy harvested from a shaken electromagnet device, specifically one that includes a coil of wire, a magnet, a bridge rectifier, a super capacitor, and a white LED. Key parameters for calculation include the size of the magnet slug, the number of coils, the frequency of shaking, and the voltage of the capacitor. By determining the energy generated per shake and multiplying it by the shakes per minute, one can estimate total energy output, accounting for losses due to friction and resistance for accuracy.
  • Understanding of electromagnetic induction principles
  • Familiarity with bridge rectifiers and their function
  • Knowledge of capacitor specifications and voltage ratings
  • Basic calculations involving frequency and energy output
  • Research "electromagnetic induction calculations" for detailed formulas
  • Explore "bridge rectifier efficiency" to understand energy losses
  • Study "super capacitor energy storage" to optimize design
  • Investigate "coil design for energy harvesting" to improve performance
Engineers, hobbyists, and researchers interested in energy harvesting technologies, particularly those working with electromagnet systems and energy-efficient designs.
Chip41
Hi all, i was wondering if you could help me calculate a few things to do with induction and electromagnets.
I wanted to look into energy harvesting or charging using electromagnets and wanted to know how to calculate the energy that is created from this product below
http://www.qfonic.com/images/products/shaketocharge/image01.jpg
It is not much more than a coil of wire, a magnet, a bridge rectifier, super capacitor and white LED. A small magnet attached to an on/off switch is used to turn on the light by activating an internal reed relay. Shaking the device forces a large magnet slug to slide back and forth inside the body of the device therefore charging the capacitor inside.
How would i work out exactly how much energy is being gathered from the shaking of this device (if that is a stupid question can you give me an example of a similar system with the WxHxB and no.of coils and size of magnet running through.. so i can get an understanding of how to calculate this.. much appraciated!)
Sorry if its a stupid question
!To calculate the energy harvested from this device, you would need to know the size of the magnet slug, the number of coils, the frequency of the shaking motion, and the voltage of the capacitor. With these values, you can calculate the amount of energy that is generated each time the device is shaken. You can then multiply that value by the number of shakes per minute to get an estimate of the total energy being generated. Additionally, you can factor in any losses due to friction or resistance in the system to get a more accurate result.
  • · Replies 22 ·
  • · Replies 16 ·
