Understanding the Mass-Energy Equivalence Concept behind E=mc2
The discussion centers around the mass-energy equivalence concept represented by the equation E=mc². Participants explore the intuitive understanding of how mass relates to energy, the definitions of units involved, and the implications of these relationships in both theoretical and practical contexts.
  • One participant expresses confusion about how mass (in kilograms) is associated with energy (in joules) through the equation E=mc², noting that neither unit was originally formulated with the speed of light in mind.
  • Another participant suggests that the units "work out" because the Joule is defined in terms of kilograms, meters, and seconds.
  • A different viewpoint argues that mass, momentum, and energy are redefined to make the equation valid, emphasizing that this redefinition aligns with Newtonian definitions at low velocities and preserves energy conservation in special relativity.
  • There is a correction regarding the notation of the equation, with one participant pointing out an error in the number of 'c's used in the formula.
  • One participant expresses bemusement at the idea that an arbitrary unit of mass can correspond to a specific amount of energy, questioning the neatness of the relationship when expressed in conventional units.
  • Another participant clarifies that the equivalence does not imply a direct relationship between energy and the distance over which a force is applied, highlighting the distinction between c² and arbitrary units of distance squared.
Participants do not reach a consensus; multiple competing views remain regarding the interpretation of mass-energy equivalence and the implications of unit definitions.
There are unresolved questions regarding the definitions of units and their implications for understanding mass-energy equivalence. The discussion reflects a range of interpretations and assumptions about the relationships between mass, energy, and the speed of light.
Jarwulf
For E=mc2
I'm having trouble understanding intuitively how every kilogram of m conveniently is associated with a neat c2 joules since as far as I know neither kg or joules were formulated with c in mind. I've seen that the mathematical derivation works out but I can't quite put it together on a qualitative level.
If you're worried why the units "work out" mysteriously, it's just that the Joule is defined in terms of kilograms, meters, and seconds.
It isn't. Mass, momentum and energy are redefined so that the formula EE=ppcccc+mmcc is true. However, the redefinition is not cavalier. It approximates the Newtonian definitions for low velocities. It makes energy conservation true in special relativity. And the relativistic quantities correspond to quantities that can be measured.
It's not any more mysterious than the Lorentz transformations which mix space and time, again with "c" coming into make the units right.
I think ou have 2 too many c's by the p's and 2 too few c's by the m's. Should be EE=ppcc+mmcccc in your notation.
Ooops, yes.
I guess I'm missing something here but I find it odd that an arbitrary unit of mass has the energy to have 1 Newton of force applied to it over the distance of exactly a lightyear squared. Its the same way if you use grams or whatever. I don't know how to explain my bemusement properly.
So the units are redefined? I usually see kg meters and seconds in the equation used although I heard any consistent set of units would work though.
Jarwulf said:
For E=mc2
In units of kilograms and joules the equivalence isn't very "neat" at all, for example one kilogram of mass would have a rest energy of 8.9875517873681764 * 10^16 joules. A more neat system would be one where one unit of mass had a rest energy equal to one unit of energy, as in Planck units. The fact that the equivalence involves such arbitrary-looking numbers when expressed in kilograms and joules is a good sign that these units weren't designed by people who knew about the equivalence in advance!
But that's not actually true, c^2 is the speed of light squared, which is totally different from "a light year squared" or any other arbitrary unit of distance squared. The equivalence says nothing about the energy needed to pushing a given amount of mass a certain distance (which would in any case depend on how quickly you wanted the mass to traverse the distance).
  • · Replies 18 ·
  • · Replies 23 ·
11K
14K
