What is the maximum height achieved by the projectile?
The discussion revolves around a projectile motion problem involving a 10kg projectile launched at an angle of 30 degrees with an initial velocity of 100 m/s from a height of 1500m. Participants are exploring how to calculate the maximum height achieved by the projectile and its impact velocity with the canyon floor.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss breaking down the initial velocity into x and y components and question the choice of equations for calculating maximum height and impact velocity. Some suggest using conservation of mechanical energy, while others propose kinematic equations. There is also a focus on the importance of considering the initial height in calculations.
Several participants have provided guidance on different approaches, including the use of kinematic equations and energy conservation. There is ongoing exploration of the correct application of these concepts, with some participants questioning the assumptions made in the calculations. The discussion reflects a mix of interpretations and attempts to clarify the problem setup.
Participants note that certain methods, such as conservation of energy, have not been covered in their coursework, which affects the approaches they can use. There is also mention of the need to account for the initial height in calculations, which adds complexity to the problem.
pinky2468
I have a question from my practice test that is supposed to be on our midterm, so I want to make sure I am doing it right!
A 10kg projectile is launched from the wall of a canyon at an angle of 30 degrees above the horizon with a velocity of 100m/s. The wall is 1500m above the canyon floor.
a)what is the maximum height achieved by the projectile?
b)what is the impact velocity with the canyon floor?
So, I did part a and I found the x and y components of v...vsin30 and vcos30.
I then found the time and used it it the equation y=Voyt + 1/2at^2 and I got y=128m
So, for part b which equation do I use? If I use pythagorean theorem the answer is 100m/s which is the same as the initial. Is that right? Or do I need to use a different equation?
why don't you use conservation of mechanical energy?
[tex]\Delta K + \Delta \Omega = 0[/tex]
For max height, you know Vy = 0, and Vx is constant, so use that. There is gravitational potential energy. You could do it with kinematics, but why bother?
Because, we have not learned that yet so I can't use the equation
Hmmm, big no on that.
You split the velocity into x-y components which is good, but your choice of formula for part 1 is somewhat questionable. See the question have not given you how long the bullet stays in the air, and therefore you would have 2 unknowns in d=ut + 1/2 at^2. it's still doable but take much more effort in figuring out the t.
Since you're only asked to figure out the height, just consider everyting in y direction. Try instead using v^2 = u^2 +2ad. (v==>final velocity, u ==> initial velocity, a ==> acceleration due to gravity, negative because it's trying to stop the bullet, d ==> distance) set v = 0 since the highest point is when the bullet is no longer going up. and give it a try. (you should get some 500ish answer)
for part b, use the same equation, but set u = 0 since you're calculating the velocity of bullet going from the top of the arc to the ground in the y direction. set d = the answer you have from part a + height of the wall, a = acceleration due to gravity, positive this time because it's accelerating the bullet.
after you figure out the final velocity in y direction, you can just add it with the x-direction velocity (which haven't changed) using pythagorean theorem.
Hope that helps
Well in that case, Remember Vy = 0 at max height. if you found the time at max height, then plug it back, show me how you found the time at max height, so i can see if its ok. By the way you got an initial position, Yo = 1500 m
Ok so I figured out the height w/o using the time,
V^2 = Vi^2 +2ay and I still get 128m
Then I used the same equation to get the final velocity of y and I set the initial velocity to 0 and I got 179m/s,
Then I used the pythagorean theorem to get the final velocity 199m/s
Does that seem right?
You're not taking into account the initial Y.
I used the same Vx because it stays constant right? Vcos30= 87m/s
Vx stays constant, yes
So, was my answer right or am I still doing something wrong inthe final equation?
yeah, that's about right, I forgot the Sin whe I did my sketch.
I did take into account the initial y... I added it to the y I found in part a for the equation to find the final velocity of y
10K
