Need help on this problem please I cant figure it out
  • Thread starter Thread starter miranda82
    Figure
The discussion revolves around a physics problem involving a 54.0 kg skateboarder who starts with a speed of 1.90 m/s and performs +80.0 J of work while experiencing -265 J of frictional work. The final speed of the skateboarder is calculated to be 5.90 m/s. The change in gravitational potential energy is determined to be 0.5 J, and the vertical height change is calculated to be 0.5 m, indicating that the skateboarder is above the starting point due to the net positive work done.
  • Understanding of gravitational potential energy (PE = mgh)
  • Basic knowledge of work-energy principles in physics
  • Familiarity with nonconservative forces and their effects
  • Ability to perform calculations involving mass, height, and energy
  • Study the work-energy theorem and its applications in mechanics
  • Learn about nonconservative forces and their impact on energy systems
  • Explore gravitational potential energy calculations in different contexts
  • Investigate the relationship between speed, work, and energy transformations
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of energy and motion in real-world scenarios.
miranda82
Need help on this problem please! I can't figure it out!
The problem is A 54.0 kg. skateboarder starts out with a speed of 1.90 m/s. He does +80.0 J of work on himself by pushing with his feet against the ground. In addition, friction does -265 J of work on him. In both cases, the forces doing the work are nonconservative. The final speed of the skateboarder is 5.90 m/s.
(a) Calculate the change (PE = PEf - PE0) in the gravitational potential energy?
J
(b) How much has the vertical height of the skater changed?
m
(c) Is the skater above or below the starting point?
above the starting point or
below the starting point ?
(a) To calculate the change in gravitational potential energy, we can use the formula PE = mgh, where m is the mass of the skateboarder (54.0 kg), g is the acceleration due to gravity (9.8 m/s^2), and h is the change in height. We can rearrange the formula to solve for h: h = PE / (mg). Since we are given the change in potential energy (PE = PEf - PE0), we can substitute this into the formula and solve for h: h = (PEf - PE0) / (mg). Plugging in the values, we get h = (80 - (-265)) / (54.0*9.8) = 0.5 m. Therefore, the change in gravitational potential energy is 0.5 J.
(b) Since we know the change in height is 0.5 m, we can conclude that the vertical height of the skater has changed by 0.5 m.
(c) Based on the given information, we can determine that the skater is above the starting point. This is because the skater has done positive work on himself (+80 J) and the final speed is greater than the initial speed. This means that the skater has gained energy and therefore must be above the starting point.
  • · Replies 98 ·
