Finding Normal & Tangent Vectors to Line: 3x-2y-4
The discussion revolves around finding normal and tangent vectors to the line represented by the expression 3x-2y-4. Participants explore the implications of the expression and its interpretation as an equation of a line.
  • The original poster attempts to derive normal and tangent vectors but expresses uncertainty about the validity of their method. They also reference a different function and question their approach. Some participants question the nature of the expression as a line and clarify the correct form of the equation.
Participants are actively questioning the assumptions regarding the expression as a line and discussing the necessary conditions for it to be considered an equation. There is a mix of interpretations being explored, particularly regarding the correct formulation of the line.
There is confusion regarding the expression 3x-2y-4 and its status as an equation, with participants noting the importance of including "=0" for it to represent a line. This highlights a potential misunderstanding in the problem setup.
Lancelot59
I figured this would be easy, I need to find the normal and tangent vectors to this line:
3x-2y-4
Well simple enough, I got the correct parametric equations for the normal, but the tangent line is being silly. I dumbed it out and got the right answer, but I think it was for the wrong reason.
I just treated the coefficients as the slope for the other variable, and it worked. I know that won't work all the time though. As shown by the next problem I did where the function was
[tex]e^{x}sin(y)=2[/tex] at the point [tex](ln(2),\frac{\pi}{2})[/tex]. I got (2,0) for the gradient at the point, and then did the same thing.
I got the correct parametric functions, but the method seems flawed. What's the proper way to do this?
hi,
you should think more about what you're doing instead of relying on formulas so heavily.
finding the tangent line to a line will be pretty trivial.
As far as the normal vector is concerned, you shouldn't have to look too far to find a solution. There are a few ways, and I suggest searching google first.
How is 3x-2y-4 a line?
dacruick said:
3x-2y-4 is not an equation!
3x-2y-4 = 0 is the equation of a line.
z = 3x-2y-4 is the equation of a plane.
Haha right you are. I honestly assumed there was an "=0". I think my brain automatically put it there.
Mine did too when I made the post.
