Comparing Complex Homework: Solving for |z|<1 & |z|>1
  • Thread starter Thread starter Ted123
    Complex Homework
The discussion revolves around the convergence of series involving complex numbers, specifically for the cases where |z|<1 and |z|>1. Participants are examining the behavior of the term \(\left | \frac{1}{n^2} \left ( \frac{1}{1+z^n} \right ) \right |\) and its implications for series convergence.
  • Mixed
  • Participants explore the validity of inequalities related to \(\left|\frac{1}{1+z^n}\right|\) for different ranges of |z|. There are attempts to apply the comparison test for series convergence, with questions about the correctness of certain inequalities and their implications for the original poster's argument.
There is an active exchange of ideas regarding the bounds of the terms involved in the series. Some participants provide alternative inequalities and suggest that the original inequalities may not hold. The discussion reflects a collaborative effort to clarify the reasoning behind the convergence of the series.
Participants are working under the constraints of homework rules, which may limit the extent to which they can provide direct solutions. The discussion includes questioning assumptions about the behavior of the terms as |z| approaches certain values.
Ted123
[PLAIN]http://img225.imageshack.us/img225/7501/complexh.jpg
Can I say that, for both [itex]|z|<1[/itex] and [itex]|z|>1[/itex] ,
[itex]\displaystyle \left | \frac{1}{n^2} \left ( \frac{1}{1+z^n} \right ) \right | \leq \frac{1}{n^2}[/itex] .
So, since [itex]\displaystyle \sum^{\infty}_{n=1} \frac{1}{n^2}[/itex] converges, [itex]\displaystyle \sum^{\infty}_{n=1} \frac{1}{n^2} \left ( \frac{1}{1+z^n} \right )[/itex] converges absolutely in both cases (a) and (b) by the comparison test?
Well, it's not true that
[tex]\left|\frac{1}{1+z^n}\right|\leq 1[/tex]
for [tex]|z|\neq 1[/tex]. However,
[tex]|1+z^n|\geq |1-|z|^n|[/tex]
so, for [tex]|z|<1[/tex] we have
[tex]\left|\frac{1}{1+z^n}\right|\leq\frac{1}{1-|z|^n}\leq\frac{1}{1-|z|}[/tex]
and for [tex]|z|>1[/tex] we have
[tex]\left|\frac{1}{1+z^n}\right|\leq\frac{1}{|z|^n-1}\leq\frac{1}{|z|-1}[/tex]
Then you can use the rest of your argument.
So how does my inequality: [itex]\left | \frac{1}{n^2} \left ( \frac{1}{1+z^n} \right ) \right | = \frac{1}{n^2} \left | \left ( \frac{1}{1+z^n} \right ) \right |\leq \frac{1}{n^2}[/itex]
follow from the upper bounds of your last 2 inequalities?
So the following is true:
[itex]\frac{1}{1-|z|} \leq 1[/itex] for [itex]|z|<1[/itex]
and
[itex]\frac{1}{|z|-1}\leq 1[/itex] for [itex]|z|>1[/itex]
and I can multiply both sides of the inequlity by [itex]\frac{1}{n^2}[/itex]
No, these two inequalities are not true. However, for [tex]|z|<1[/tex]
[tex] \left|\frac{1}{n^2}\left(\frac{1}{1+z^n}\right)\right|\leq\frac{1}{n^2}\frac{1}{1-|z|}=\frac{C}{n^2}[/tex]
and so the series are convergent, by comparison test. The same for [tex]|z|>1[/tex]. Your upper bounds were slightly wrong, but the idea of comparing with [tex]\frac{1}{n^2}[/tex] was ok.
