Time reversal symmetry breaking
The discussion revolves around the concept of time-reversal symmetry breaking in the quantum Hall effect (QHE). Participants explore the implications of magnetic fields and vector potentials in quantum mechanics, particularly how these relate to time-reversal operations and the resulting symmetry properties of the system.
  • Some participants note that both velocity/momentum and magnetic fields are odd under time-reversal operations, questioning how time-reversal symmetry can be broken in the QHE.
  • Others argue that the magnetic field is often treated as 'external,' and with its direction fixed, the system inherently breaks time-reversal symmetry.
  • There is a discussion about the Hamiltonian formulation, where participants express uncertainty about how the Hamiltonian remains invariant under time-reversal despite the presence of an external magnetic field.
  • One participant suggests that to determine time-reversal symmetry, one must construct the time reversal operator and analyze the commutator with the Hamiltonian, indicating that a non-zero commutator implies broken symmetry.
  • Another viewpoint introduces the concept of Chern numbers and their relation to quantized conductivity as a means to argue about time-reversal symmetry in the QHE.
  • Some participants express confusion regarding the implications of time-reversal symmetry in the context of topological insulators, contrasting the QHE with the quantum spin Hall effect (QSHE) and discussing the role of spin-orbit coupling.
Participants do not reach a consensus on the implications of time-reversal symmetry breaking in the QHE. Multiple competing views are presented regarding the treatment of magnetic fields, the role of the Hamiltonian, and the interpretation of time-reversal operations.
There are limitations in the discussion regarding the assumptions made about the external magnetic field and its treatment in the Hamiltonian. The relationship between time-reversal symmetry and the specific conditions of the system remains unresolved.
hbaromega
We know velocity/momentum and magnetic field both are odd to time-reversal operation. Then how is the time-reversal symmetry broken in quantum Hall effect since magnetic field is always coupled with velocity/momentum?
In quantum mechanics, the effect of magnetic field is included by using the vector potential (A). This is done by replacing the momentum operator p by (p-eA/c). Now both p and A are odd under time reversal.
It's not the force which determines whether the system is time reversal invariant or not.
You are right indeed, but here, the B field is usually considered 'external'.
With the direction of the 'external' B field fixed, the system certainly breaks time-reversal.
I though it should be equivalent. When symmetry is held, the laws would be the same after symmetry operation. Both in Hamiltonian or the force.
Even if I consider the Hamiltonian, doesn't it come like
H=(p-eA/c)^2 ?
Now when we apply T-reversal operator p and A both change sign. Then overall Hamiltonian remain invariant. Then how do we get T-reversal symmetry breaking in quantum Hall effect after applying magnetic field?
Sorry didn't get what you meant by 'external'. Doesn't it become a part of the Hamiltonian? In Landau level we indeed solve the Hamiltonian
H=(p-eA/c)^2/2m
* Sorry ! I missed the 2m term in earlier post.
Okay..sorry I was a bit sloppy in the last post!
To determine if a system has time reversal symmetry, what should we do?
We must construct the time reversal operator (T). For fermions (as in this case) this would be exp(i*pi*Sy).
Where Sy is the pauli matrix. Now if the commutator of Hamiltonian H and T vanishes, then we can conclude that the system has time reversal symmetry. Not otherwise!
Now for this (QHE) case let us choose the Landau gauge A=(By,0,0) and thus the magnetic field is constant and in the z direction.
If you calculate the commutator you will realize that it is non zero. And hence time reversal symmetry is broken in this system.
Another way to argue this is to use what are called the Chern numbers, which in this case are the quantized values of conductivity. I suggest that you go through this paper:
Mahito Kohmoto, Topological invariant and the quantization of the Hall conductance
Annals of Physics
Volume 160, Issue 2, 1 April 1985, Pages 343-354
H=(p-eA/c)^2/2m
That means, when you perform the time reversal, you don't change the direction of the magnetic field (or equivalently, A).
Suppose you are measuring the Hall conductivity of a sample. If you just look at the sample, its behavior breaks the time-reversal symmetry. (B field is a fixed quantity here.) However, if you take the sample plus the magnet as your system, it preserves the time-reversal symmetry as a whole.
Annals of Physics
I think, there should be an extra conjugation operator as well (as K in Sakurai's Mod. Q. M. Chapter 4). But still I'm not clear how to operate to show whether TR symm. broken. I can only understand that it can change up-spin ket to a down-spin ket.
Thanks for the reference. I looked at the paper though need to spend time fully understand. But I think, he is one of the proposers of TKNN invariant in QHE. I roughly understand the topology argument which connected to Berry phase that appears due to periodicity of the Bloch wave function.
Actually my question arises due to topological insulator context. People say that TR symmetry is broken in QHE, where spin degeneracy is maintained, but TR is symm. is preserved in QSHE where spin degeneracy is lifted due to strong spin orbit coupling.
Now spin orbit coupling looks like S.L .Since S and L both are odd to TR, together they become invariant.
However, how can I show that this cannot happen to Ferromagnet or QHE where we expect similar interaction term in the Hamiltonian?
Sound pretty confusing to me!
So you mean in the process of T-reversal I'm not looking at the magnetic field ! So is it like what happens if I put a magnetic field in the same direction when the system is under T-reversal ?
  • · Replies 17 ·
