Fluid Mechanics Density problems
The discussion focuses on solving density problems in fluid mechanics, specifically using the formula Density = mass/volume. A 6-kg piece of metal displaces 1 liter of water, confirming its density as 0.006 kg/cm³. For a 2.0-kg object suspended in water with a measured mass of 1.5 kg, the density is calculated as 1.333 kg/m³. The average density of a vacationer floating in ocean water, with 90% of their body submerged, is determined to be 0.1025 kg/m³, utilizing Archimedes' principle and the known density of ocean water at 1.025 kg/m³.
  • Understanding of density calculations in fluid mechanics
  • Familiarity with Archimedes' principle
  • Basic knowledge of mass and volume units (kg, m³, cm³)
  • Ability to manipulate algebraic equations
  • Study the principles of buoyancy and Archimedes' principle in depth
  • Learn about the relationship between density, mass, and volume in different fluids
  • Explore advanced fluid mechanics concepts such as hydrostatics and hydrodynamics
  • Investigate real-world applications of density calculations in engineering and environmental science
Students and professionals in physics, engineering, and environmental science who are looking to deepen their understanding of fluid mechanics and density-related calculations.
Susan
Is this correct?
A 6-kg piece of metal displaces 1 liter of water when submerged. What is its density?
Density = mass/volume 1 liter of water = 1000 cm3 = 1 kg
Ans: 6 kg / 1000 cm3 = .006 cm3
How would this one work out?
When a 2.0-kg object is suspended in water, it ‘masses’ 1.5 kg. What is the density of the object?
I'm guessing:
Density = mass/volume = 2.0 kg/1.5 kg = 1.333
Or 2.0 kg/ 1500 cm3 = .00133 cm3
Now I'm totally lost on what to do:
A vacationer floats lazily in the ocean with 90% of his body below the surface. The density of the ocean water is 1.025 kg/m3. What is the vacationer’s average density?
The buoyant force is equal to the weight of the water displaced (Archimedes principle). That allows you to do a force balance from which you can ultimately determine the volume of the swimmer!
Your calculations for the first two problems are correct. For the third problem, we need to use the equation Density = mass/volume. We know the density of the ocean water (1.025 kg/m3) and we can assume that the vacationer's body has the same density as water (since they are floating). So, we can set up the equation as follows:
1.025 kg/m3 = mass/volume
We know that 90% of the vacationer's body is below the surface, so we can assume that 90% of their volume is also below the surface. This means that their volume above the surface is 10% of their total volume. We can represent this mathematically as:
Volume = 0.1 x total volume
Now we can substitute this into our equation to solve for the vacationer's average density:
1.025 kg/m3 = mass/(0.1 x total volume)
We can rearrange this to solve for mass:
mass = 1.025 x 0.1 x total volume
And we know that mass is equal to the weight of the vacationer, so we can represent this as:
weight = 1.025 x 0.1 x total volume
Finally, we can divide both sides by the total volume to solve for the vacationer's average density:
average density = weight/total volume = (1.025 x 0.1 x total volume)/total volume = 0.1025 kg/m3
So, the vacationer's average density is 0.1025 kg/m3.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 18 ·
