Tensor Rank of 2X2 Matrix: Is It Always 2?
  • Context: Graduate
  • Thread starter Thread starter siyacar
    Matrix rank Tensor
The discussion centers on the tensor rank of a 2x2 matrix and its relationship to the matrix rank. The specific example provided is the matrix |1 1| |0 1|, which has a matrix rank of 2. The tensor rank is defined as the minimum number of diads required for decomposition, leading to the conclusion that the tensor rank of this matrix is also 2. Furthermore, the discussion highlights that the rank of a 2x2x2 array can vary based on the field of the entries, asserting that it is 3 for real numbers but 2 when considered over complex numbers.
  • Understanding of matrix rank and tensor rank definitions
  • Familiarity with matrix decomposition techniques
  • Knowledge of real and complex number fields
  • Basic concepts of linear algebra and tensor analysis
  • Research the definitions and properties of tensor rank in detail
  • Explore matrix decomposition methods, specifically for tensors
  • Study the impact of different fields (real vs. complex) on tensor rank
  • Learn about higher-dimensional arrays and their ranks, such as 2x2x2 and 4x4x4 tensors
Mathematicians, students of linear algebra, and researchers in tensor analysis who are looking to deepen their understanding of matrix and tensor ranks.
siyacar
Should not the definition of "Rank" agree in the two cases below? :
1)rank of a 2X2 matrix and
2) "tensor rank" of the same 2X2 matrix
Here is my particular example?
|1 1|
|0 1|
This matrix has rank 2. What is its tensor rank? Still 2?
Thnk you
You should start from the definitions. What is the <rank> of a tensor defined to be ?
Thank you for your response.
Background: I am just learning the notion of tensor rank. My real effort was understanding a certain article where
2x2x2 and 4x4x4 etc, arrays are involved. I was warming up, so to speak, and ran into some problems.
I do know the definition of tensor rank I believe. It is the minimum number of "diads" in the decomposition (in the case of a matrix), and the minimum number of "triads"
used in the decomposition for a 2x2x2 array.
So if @ denotes the tensor rank, the matrix I have posted shoud have tensor rank 2 since it can be written as:
(1,0) @ (1,1) + (0,1) @ (0,1)
Here is my question:
I will write a 2x2x2 array below; by first writing the front face as a matrix and the back face as a matrix.
Front |-1 0| Back |0 1|
|0 1| |1 0|
In this article it is asserted that the rank if this 2x2x2 array is 3, BUT it 2 (not 3) if the entries are considered to be Complex numbers instead of Real numbers.
I was trying to verify this (I was not able to).
If the assertion is correct, then, while the rank of a matrix does not depend on the base field of the entries, it does depend on the filed for a 2x2x2 array.
Any help is appreciated in verifying that the tensor rank is 2 for this array when considered as Complex entries. I thank you for your time
  • · Replies 33 ·
