How much time does it take to lift the piano?
  • Thread starter Thread starter BlackMamba
    Lift Piano Time
The discussion centers on calculating the time required to lift a piano weighing 140 kg to a height of 18.0 meters using a crane that produces a power output of 400 W. The correct approach involves using the equation P = Fv, where P is power, F is force, and v is velocity. By determining the force exerted by the crane and the acceleration, the time to lift the piano is calculated to be approximately 113.21 seconds. This solution is derived from applying Newton's laws and the relationship between power, force, and velocity.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of power and work
  • Basic knowledge of algebra for rearranging equations
  • Ability to apply the equation P = Fv in physics problems
  • Study the relationship between power, force, and velocity in physics
  • Learn how to apply Newton's laws to solve real-world problems
  • Explore the concept of work done against gravitational force
  • Investigate the implications of steady speed on kinetic energy
Students studying physics, engineers involved in mechanical design, and anyone interested in understanding the dynamics of lifting heavy objects using cranes.
BlackMamba
Hello,
I thought I knew how to solve for this problem but alas I was wrong. I'm hoping someone will be able to point me in the right direction.
Here's the problem: A 1.40x10^2 kg piano is being lifted at a steady speed from ground level straight up to an apartment 18.0m above the ground. The crane that is doing the lifting produces a steady power of 4.00x10^2 W. How much time does it take to lift the piano?
So here's what I did:
The equation for power is P = W/t.
The equation for W (work done) is W = (Fcos0)s.
I have P (at least this is my thinking here). P is 4.00x10^2 and I would need to find W and then I could solve for t.
F = ma, however I don't know what my acceleration is. I calculated it with 9.80 but my answer was incorrect. So if all my original thinking in finding t is correct then all I really need help with is finding F.
Any help provided will be greatly appreciated.
Stunner, that does not equal work.
Conservation of Mechanical Energy
[tex]\Delta K + \Delta \Omega = 0[/tex]
By the way, if the speed is steady(i suppose it means constant) what will be the change of kinetic energy?
You could apply (Conservative System Work)
[tex]W = -\Delta \Omega[/tex]
Alternatively,
Newton's 1st Law
[tex]\sum_{i=1}^{n} \vec{F}_{i} = 0 \rightarrow \vec{v} = constant[/tex]
You could use this to establish the force exerted to lift it is equal to the weight of the piano, in magnitude.
Hi there,
To solve this problem, it would be helpful to use the equation P = Fv, where P is power, F is force, and v is velocity. In this case, we know that P = 4.00x10^2 W and v = 18.0 m/s (since the piano is being lifted at a steady speed of 18.0m above the ground). Therefore, we can rearrange the equation to solve for F: F = P/v. Plugging in the values, we get F = (4.00x10^2 W)/(18.0 m/s) = 22.22 N.
Now, we can use the equation F = ma to solve for the acceleration. We know that m = 1.40x10^2 kg, so we can rearrange the equation to solve for a: a = F/m. Plugging in the values, we get a = (22.22 N)/(1.40x10^2 kg) = 0.159 m/s^2.
Finally, we can use the equation v = at to solve for the time (t) it takes to lift the piano. We know that v = 18.0 m/s and a = 0.159 m/s^2, so we can rearrange the equation to solve for t: t = v/a. Plugging in the values, we get t = (18.0 m/s)/(0.159 m/s^2) = 113.21 seconds.
Therefore, it would take approximately 113.21 seconds (or 1 minute and 53 seconds) to lift the piano. I hope this helps and please let me know if you have any further questions.
10K
