Causal structure of spacetime: intuitive reason for non-compactness?
jarlostensen
Apologies in advance if this has been asked and answered somewhere else, I searched but could not find anything.
I just wanted to verify if my intuitive understanding of why space time (if it is to be physically plausible) can not be compact.
According to Hawking and Ellis (and others) space time can not be compact because it would allow for the existence of closed time like curves. I understand (I think) that argument based on limit points, or accumulation points, which define a (sequence) compact space and how this allows such curves to exist.
Now, is it also correct, and much simpler, to assume that *if* space time was compact, this would imply "special" points in space time (i.e. the limit points) which breaks the principle of relativity, somehow...?
I.e. if space time is compact, then there exists an arbitrary number of points which are the accumulation points for sequences of time like curves and (ignoring *completely* the closed-timelike curve problem) this would imply that geodesics would be influenced by other things than just mass/energy (as the causal argument is independent of any solution to Einstein's field equations.)
Or am I very very far off on a tangent indeed..?
I wonder if the following will help:
http://arxiv.org/PS_cache/arxiv/pdf/1005/1005.2591v1.pdf
The author, Paul Kinlaw, recently finished his PhD in math and talked about it where I am. Its a bit mathy (essentially a topology paper) but I think it addresses what you're interested into some degree. The problems he's interested in were originally motivated in physics but he's a few degrees removed and so has some trouble fielding those types of questions. I straddle math and physics but have yet to really study GR (soon...very soon).
I hope it helps.
Thank you for your response, the article looks very interesting and I'm rolling up my sleeves and digging into it! If I get to some sort of epiphany I'll post a follow up.
George Jones posted the proof of this part (or most of it anyway) here.
Thanks Fredrik, I was following Wald's book on GR plus what I could gleam from "The Large Scale Structure of Space Time" on Google books - I think George Jones' reply that you refer to is very clear and helpful - I'm going to wrap my head around this last part in particular (I think it holds a clue to the epiphany I need to get to):
...Consequently, p_1 is in I+(p_1), i.e., there exists a smooth, future-directed timelike curve from p_1 to p_1.
I.e. that a finite subcover and, perhaps on an equally fundamental level, that "M" is Hausdorff, means that points will inevitably lie in their own chronological- and causal -future.
Perhaps this has some relevance to my starting point, i.e. that this also implies that space has some sort of "preferred structure" which would imply non-matter originating effects which could not be encoded in the Einstein tensor and hence are unphysical (leading to compact space times being unphysical) - but that part is still something I'm trying to understand (and I am starting to suspect that it's just plain wrong)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
