Non linear curve fit - parameter accuracy
4 replies · 9K views · last reply
arwelbath
Hi,
Suppose i fit some data with a curve, using Levenberg-Marquardt (or equivalent). How do I estimate the accuracy of the parameters (by this i mean p plus or minus something). I've read somewhere that its done using the jacobian and covariance matricies I think, but not sure. Anyone know if there's a 'standard' way of doing this?
Cheers
arwelbath said:
Hi,
Cheers
most usually you determine the difference between each point you fit and the fitted point and you square all these difference and sum them, you then divide this sum by the number of points you have summed and call this "the mean squared error" (tip: google this).
arwelbath said:
Hi,
Cheers
As I read in an old Origin Help, the standard error of the i-th parameter of a given parameter set p is
[tex]\sigma_i=\sqrt{\chi^2(\bold{p})C_{ii}}[/tex]
where C is the variance-covariance matrix. It is calculated from the Jacobian F ([tex]F_{i,j}=\partial f(\bold{p},x_j)/\partial p_i)[/tex] as
[tex]\bold{C}=(\bold{F}^{'} \cdot \bold{F})^{-1}[/tex]
If you understand this, explain me, please! :smile:
ehild
Erm. Thanks gerben for the definition of chi squared. Not quite what I was after.
The "Numerical recipes in .." books have a discussion of this. You can find the C book online at
http://www.library.cornell.edu/nr/bookcpdf.html
The second half of chapter 15 discusses non-linear fitting and uncertainty of the estimated parameters
