Is a this function differentiable?
  • Context: Undergrad
  • Thread starter Thread starter SprucerMoose
    Differentiable Function
The discussion revolves around the differentiability of a function that is continuous and differentiable for all x in the real numbers, but whose domain is restricted to a closed interval [a,b]. Participants explore whether the derivative exists at the endpoints x=a and x=b.
  • One participant questions if the derivative exists at the endpoints of a closed interval for a function that is continuous and differentiable everywhere.
  • Another participant notes that according to Rudin, there is a notion of a one-sided derivative, but in many cases, derivatives at the endpoints are undefined.
  • Some participants assert that endpoints on a closed interval would have no derivative.
  • A participant expresses confusion about the lack of a unique derivative at the endpoints, suggesting it seems intuitive that one should exist.
  • One participant argues that if the function is differentiable for all x in R, it should also be differentiable at x=a and x=b, but clarifies that the definition of the derivative at x=a relies on values from an open interval around a, raising semantic concerns about the term "restricted."
  • A later reply challenges the tone of the previous response while reiterating the technical nature of the question regarding the definition of a derivative.
Participants express differing views on whether derivatives exist at the endpoints of the interval, with some asserting they do not and others suggesting that one-sided derivatives may apply. The discussion remains unresolved with multiple competing perspectives.
The discussion highlights the dependency on definitions and the implications of restricting the domain of the function, as well as the semantic nuances involved in the concept of differentiability at endpoints.
SprucerMoose
Hi all,
I was just wondering if a function that is continuous and differentiable for all xεR, but where the domain is restricted to closed interval [a,b], does the derivative exist at x=a or x=b?
It depends on your context.
According to Rudin (an analysis textbook author) there is a notion of a onesided derivative but in most cases the derivatives at the endpoints are underfined
End points on a closed interval would have no derivative.
Thanks a lot guys.
Is there a reason? Intuitively it seems like there should be a unique derivative, and you could evaluate it.
If the function is differentiable for all x in R, then obviously it is differentiable at x = a and x = b.
But the definition of the derivative at x = a depends on function values at all points in an open interval containing a.
So this is a semantic question about what you mean by the word "restricted". First you said the function was differentiable everywhere, then you chose to ignore the fact that it was defined outside the interval [a,b] for some reason.
If the function is not defined outside the interval [a,b], then the most you can say is that there is a one-sided derivative at the end points of the interval.
Do you have a problem with that?
I'm asking a technical question so i can gain a better understanding of how a derivative is defined. Your answer is concise and appreciated, but your condescending tone is not.
  • · Replies 46 ·
