Is the hydrogen molecule bonding really covalent?
The discussion revolves around the nature of bonding in the hydrogen molecule (H2), specifically examining whether the bonding can be classified as covalent or ionic. Participants explore this topic through various theoretical frameworks, including molecular orbital (MO) theory and valence bond theory, while considering the implications of different modeling approaches.
  • One participant describes constructing molecular orbitals for H2 and suggests that the hydrogen molecule exhibits covalent bonding with a minor ionic component based on their calculations.
  • Another participant counters that for homonuclear dimers like hydrogen, the concept of ionic bonding is problematic due to the absence of persistent partial charges, arguing that the leading determinant in a configuration interaction (CI) expansion is predominantly covalent.
  • A third participant notes that the value of the parameter lambda in the wave function is dependent on the chosen basis set, indicating that different basis sets can yield significantly different results regarding the ionic character.
  • This participant also mentions that ionic structures can be avoided in valence bond calculations by using hybridized orbitals, referencing a specific article for further reading.
  • Additionally, they propose that Bader analysis could provide an objective measure of ionicity in the hydrogen molecule.
  • Another participant introduces a qualitative perspective, stating that the electronic wavefunction is purely covalent at infinite nuclear separation and that ionic structures are energetically unfavorable in that limit.
Participants express differing views on the classification of bonding in the hydrogen molecule, with some supporting the idea of a covalent bond with ionic character, while others argue against the presence of ionic bonding in this context. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight that the conclusions drawn may depend on the choice of basis set and the specific theoretical approach used, indicating limitations in the models discussed.
eoghan
Hi there!
I'm studying the hydrogen molecule. According to the MO technique I start from one-electron molecular orbitals to construct the wave function of the entire molecule.
Afa hydrogen is concerned, I can construct two [tex]^1\Sigma_g[/tex] orbitals:
[tex]\Phi_A=\Phi_g(1)\Phi_g(2)\chi_{0,0}[/tex]
[tex]\Phi_B=\Phi_u(1)\Phi_u(2)\chi_{0,0}[/tex]
Where [tex]\Phi_g(i)[/tex] means that the i-th electron is in the gerale orbital obtained from the one-electron molecule.
Computing the energies for [tex]\Phi_A[/tex] and [tex]\Phi_B[/tex] it is found that only [tex]\Phi_A[/tex] is a bonding orbital, so that the wave function of the hydrogen molecule is [tex]\Phi_A[/tex] where the two electrons are both in the gerale orbital with antiparallel spins.
To improve the accuracy of the model, a linear combination of [tex]\Phi_A[/tex] and [tex]\Phi_B[/tex] can be considered:
[tex]\Phi_T=\Phi_A+ \lambda \Phi_B[/tex]
using this wave function as the trial function for a variational method, [tex]\lambda[/tex] can be found.
Now, this wavefunction can be rewritten as a sum of a covalent bonding wavefuntion and a ionic bonding wavefunction:
[tex]\Phi_T=(1- \lambda )\Phi_A^{COV}+(1+ \lambda )\Phi_A^{ION}[/tex]
and it is found that the coefficient for the ionic bonding is 20% of the coefficient of the covalent bonding.
So.. can I say that the hydrogen molecule is covalent, but with a little part of ionic bonding?
I think homonuclear dimers, like hydrogen, are some of the few species where one cannot say that. Ionic bonding implies the existence of persistent partial charges, and these you cannot have in a such molecules. Also I believe that the weight of the leading determinant in a CI expansion for H2 is much higher than 80% if one does a full variational calculation with more degrees of freedom in the basis set (I seem to recall something like 98%).
In general, however, "covalent bonding" and "ionic bonding" are more qualitative of a concept, so whenever you have some bonding/antibonding orbital pair where the bonding orbital has a higher occupation, you can say there is some covalent bonding, and whenever there are partial charges, you can say there is some ionic bonding (at the same time).
You should take in mind that the value of lambda is basis set dependent. And changes drastically e.g. by going from a basis of Hydrogen 1s orbitals to orthogonalized s orbitals.
On the other hand, ionic structures can be avoided at all in a valence bond calculation of H2 by using a basis of orbitals in which some of the orbital on the other atom is hybridized, i.e. phi_1= a*s_1 +b*s_2 and phi2=-b*s_1 +a*s_2.
See, e.g.,
@article{mcweeny1988hybridization,
title={{Hybridization in valence bond theory: The water molecule}},
author={McWeeny, FE and others},
journal={Journal of Molecular Structure: THEOCHEM},
volume={169},
pages={459--468},
issn={0166-1280},
year={1988},
publisher={Elsevier}
Probably the best measure would be some Bader analysis
http://en.wikipedia.org/wiki/Bader_analysis
to assess in a somewhat objective way the amount of ionicity.
A more qualitative proceedure would be the following: The electronic wavefunction is purely covalent in the limit of infinite separation of the nuclei and the purely ionic structure is always (infinitely) above the covalent in that limit. When the atoms are brought close, the ground state is mainly covalent if there is no avoided intersection between the potential curves.
Thank you!
  • · Replies 16 ·
