What is a Farnboro Engine Indicator and How is it Used?
  • Thread starter Thread starter monty37
    Engine
The discussion centers around the Farnborough engine indicator, its function, and its relevance in modern engine analysis. Participants explore the historical context of the device, its operational principles, and current alternatives in measuring engine performance.
  • Exploratory, Technical explanation, Debate/contested
  • One participant asks for clarification on what a Farnborough engine indicator is and its uses.
  • Another participant explains that it is an early mechanical device used to create an indicator diagram for internal combustion engines, plotting pressure against volume to measure work done by the gas.
  • A different participant expresses concern about the lack of detailed explanations regarding the principle and experimental setup of the Farnborough indicator, questioning its current relevance.
  • It is noted that modern practices favor electronic pressure transducers that provide faster and more accurate measurements correlated with crank angle for generating indicating diagrams.
Participants express differing views on the relevance of the Farnborough indicator today, with some suggesting it may be obsolete in light of modern technology, while others focus on its historical significance.
There are mentions of missing details regarding the operational principles and experimental setups of the Farnborough indicator, as well as the implications of transitioning to electronic methods for engine analysis.
monty37
what is a farnboro engine indicator and what is it used for?
For an IC engine, an "indicator diagram" is a plot of pressure against volume in the cylinder over the engine cycle, which measures the work done by the gas.
The Farnborough indicator was an early mechanical device to measure this, before electronic pressure transducers etc were available.
Googling for "Farnborough Indicator" will find you more details (note the correct spelling).
I did find details but the principle ,experimental setup etc are not explained ,is this
indicator obsolete now ?
Everyone uses pressure transducers now, these are read at high speed and correlated against crank angle electronically to give an indicating diagram.
  • · Replies 26 ·
