Am I being punked? (Physics problem)
  • Thread starter Thread starter Tatum
The discussion revolves around a kinematics problem related to estimating the speed of sound based on the time interval between a lightning flash and the subsequent thunder. Participants are exploring the implications of a rule of thumb that suggests every five seconds corresponds to a distance of one mile.
  • Participants discuss the relationship between time and distance in the context of sound travel, questioning how the five-second interval translates to miles. Some consider the conversion of miles to meters and the implications of estimating speed without prior knowledge of the speed of sound.
There are various interpretations of the problem, with some participants providing insights into the conversion of miles to meters and the estimation of speed. While some guidance has been offered regarding assumptions about the speed of sound, no consensus has been reached on the approach to solving the problem.
Participants note the absence of specific temperature conditions that could affect the speed of sound, and there is mention of differing interpretations of the problem's requirements. The discussion reflects a mix of assumptions and calculations without definitive conclusions.
Tatum
This was problem 7 in the homework from the 2nd chapter(Kinematics in one dimension) of my physics book:
According to a rule of thumb, every five seconds between a lightning flash and the following thunder gives the distance of the storm in miles. Assuming the flash of light arrives in essentially no time at all, estimate the speed of sound in m/s from this rule.
The answer was 300 m/s. I figure I would need speed of light and sound but the speed of sound isn't anywhere in this book. Wouldn't I need to know how many miles would equal 5 seconds? I need help, thanks
arent they saying that it takes 5 seconds per mile for the sound to get there? how they said every five seconds between them gives the distance in miles... so that would be like saying every 5 seconds is one mile... i think
If a mile is 5280 feet and sound takes 5 seconds to travel that far then it travels about 1000 feet per second. The speed of light is about 186,000 miles per second so for all intents it is instantaneous.
The actual speed of sound is a function of temperature and pressure (altitude) but it doesn't change all that much. To understand a concept a first order answer is more than adequate.
Pay attention in your physics class as it is the study of the physical world and will be of value to you all your life. That is more than I can say of many classes.
Good luck
Kirk
Speed of sound
If you're not given an air temperature, you can just use 331 m/sec as the speed of sound.
The speed of sound was supposed to be estimated. THis means you do not need the speed of sound to begin with.
Every track star knows that the "metric mile" is 1500 meters. (This is actually .92 miles, but it's close). If 1500 meters in 5 seconds, then how fast?
300 m/s
So for the problem, every 5 seconds is 1 mile. 1 mile = 1.61 km = 1610 meters. That's 322 meters per second which is about 300 m/s. Whoa DUDES! Thanks a lot, I'm on the road to my noble prize!
Tatum said:
300 m/s
You mean Nobel Prize? :-p
