Calculate LED Current Draw w/ Resistor & 5V Supply
  • Thread starter Thread starter tangodirt
    Current Led
The discussion revolves around calculating the current draw of an LED in a circuit with a 5V power supply and a series resistor. It includes theoretical considerations and practical calculations related to LED operation and circuit analysis.
  • One participant seeks to understand how to calculate the current flowing through an LED given a specific resistor value in a circuit.
  • Another participant suggests using Kirchoff's Voltage Law to find the voltage across the resistor and then applying Ohm's Law to calculate the current, noting that the current through the resistor equals the current through the LED in a series circuit.
  • A later reply confirms the initial participant's understanding, acknowledging the simplicity of the calculation after receiving clarification.
  • Another participant advises checking the LED datasheet for typical operating voltage at a specified current, providing a formula to calculate current based on the forward voltage and resistance.
  • This participant also calculates the required resistance for a standard LED at a specified current and warns about the power dissipation in the resistor.
Participants generally agree on the method to calculate the current through the LED using circuit laws, but there are variations in the specific values and assumptions regarding the LED's forward voltage and current specifications.
Participants reference different forward voltages for the LED, indicating potential variability based on the specific LED model and its datasheet. The calculations depend on these values and assumptions about the circuit configuration.
Individuals interested in electronics, particularly those working with LEDs and basic circuit design, may find this discussion relevant.
tangodirt
Simple question for you guys. I am trying to drive an LED with a 5V power source and a resistor in series.
I understand how to calculate the minimum resistance needed to drive the LED with maximum current ((voltage supply - forward voltage) / maximum current) but I can't for the life of me figure out how to calculate the current through an LED with a given resistor.
Say, we have our 5V source --> 330 ohm resistor --> LED with forward voltage of 3.15V --> ground. What's the current flowing through the circuit?
By applying Kirchoff's Voltage Law, you know the voltage across the resistance (supply voltage - forward voltage).
With this, you can apply Ohm's Law to calculate the current through the resistor (you know the voltage across it and the resistance). Since it is a series circuit, the current through the resistor = the current through the LED.
Ugh, of course. Too simple. I knew I had enough information to back that number out, I suppose it has just been a long day and my brain already went into weekend mode. Thanks!
You'll want to check the LED datasheet for typical operating voltage @ specified current.
Assuming a standard 5mm LED: White @ 20mA
(Vin - Vf) / R = I
Vin = 5 V
Vf = 3.2V (found from LED datasheet @ 20mA)
I = 0.02A
5V - 3.2 / R = 0.02A
R = 90 Ohm
Dont burn up your resistor! Calculate power in R:
P = I^2 * R
P = (0.02 * .02) * 90
P = .036W
  • · Replies 44 ·
  • · Replies 19 ·
