Remapping Computer Circuitry to Avert Impending Bottlenecks
The forum discussion centers on the implications of remapping computer circuitry to prevent bottlenecks in processing power. It clarifies that the introduction of multiple cores in processors was primarily driven by the limitations of increasing clock speeds due to excessive heat generation, rather than simply expanding die size. The conversation also highlights that while current technology remains sufficient, significant advancements such as copper interconnects and high-k/low-k dielectrics have occurred. Lastly, it asserts that while algorithmic changes may not be necessary, understanding memory and processor proximity can enhance performance.
  • Understanding of multi-core processor architecture
  • Knowledge of semiconductor manufacturing processes
  • Familiarity with computer architecture concepts like cache levels
  • Basic comprehension of algorithm optimization techniques
  • Research the impact of heat generation on CPU design
  • Explore advancements in semiconductor materials, specifically copper and high-k dielectrics
  • Learn about cache optimization techniques and their role in performance
  • Investigate the use of SSE instructions for explicit memory management
Computer engineers, semiconductor manufacturers, and software developers focused on optimizing processing efficiency and understanding the evolution of CPU architecture.
Simfish
Technology news on Phys.org
I don't see any major change described in this article. Just a lot of buzzwords.
One thing is completely wrong in this article: multiple cores were not added because more real-estate became available. That is completely ridiculous. You can make the die as large as you want. Multiple cores came into existence because of excessive heat generation: the clock speed could no longer be increased, so extra cores were added to increase processing power.
And the absence of a “major breakthrough” is simply because the current technology was/is still good enough. “Computer designers” will not make the change. Semiconductor manufacturers will. That's only going to happen when it makes sense financially. Fabs are really expensive as is.
EDIT: there were major breakthroughs by the way. Copper was a huge one around the turn of the millennium. High-k/low-k dielectrics also. So Mr. "Computer Designer" should probably not talk about things he has no clue about.
Regarding the algorithms, the math is still the same. The implementation does not really matter. If anything, it gives you job security.
EDIT2: if what the article claims does indeed happen, it's not clear whether you will have to change the algorithms. The idea of bringing memory and processor closer is not new at all. Your CPU has level-1 and level-2 caches. It's all transparent though. You can take advantage of them explicitly if you want to (with some SSE instructions), but it's not required. It could be done the same way.
