Designing a High Performance Two Cylinder Eccentric Circular Cam Piston Pump
  • Thread starter Thread starter bigdogt33
    Cam Circular
The discussion centers on designing a two-cylinder eccentric circular cam-type piston pump to achieve a flow rate of 0.65 m³/s at a rotational speed of 110 rad/s. The user calculated the required volumetric flow rate by adjusting for a volumetric efficiency of 75%, resulting in a flow rate of 0.867 m³/s. By determining the number of strokes per second (17.5) and equating it to the volume of the two cylinders, the user concluded that both the stroke length and piston diameter should be 12.6 cm. This calculation is confirmed as correct based on the provided parameters.
  • Understanding of fluid dynamics and pump design principles
  • Familiarity with volumetric efficiency calculations
  • Knowledge of rotational motion and its impact on pump performance
  • Basic geometry related to cylinder volume calculations
  • Research "Volumetric efficiency in piston pumps" for deeper insights
  • Study "Fluid dynamics principles for pump design" to enhance understanding
  • Explore "Calculating cylinder volumes in engineering applications" for practical applications
  • Investigate "Eccentric cam mechanisms in mechanical design" for advanced design techniques
Mechanical engineers, students in fluid mechanics, and professionals involved in pump design and optimization will benefit from this discussion.
bigdogt33
This is actually a homework question that i am confused about.
This is the question.
Design a two cylinder eccentric circular cam-type piston pump to deliver a flow rate of 0.65 m^3/s at a rotational speed of 110 rad/s. Let the stroke length equal the piston diameter and assume a volumetric efficiency of 75%. I need to find the stroke length and piston diameter.
Thanks for anyone who helps
Think about how to figure out the volume required per each stoke from the givin information. Then what is the volume of a "square cylinder"?
i started by taking the 110 rad/s and dividing by 2pi to get 17.5 revolutions per sec. Then 1 stroke length per revolution which in turn gets 17.5 strokes lengths per sec to get shaft speed.
since it required a flow rate of .65, I divided that by 0.75 efficiency to get 0.867 m^3/s
then i divided that by 17.5 and set the whole thing equal to stroke length times the volume of the two cylinders.
Found the diameter and stroke length to equal 12.6 cm.
Is this correct or did i make a mistake?
10K
