So can you add elements to illegal drugs to make them technically different?
  • Thread starter Thread starter Black Hole
    Drugs Elements
The discussion revolves around the potential for modifying the chemical structure of illegal drugs, specifically focusing on the addition of elements such as oxygen or inert gases to substances like marijuana. Participants explore the implications of such modifications from a chemical and biological perspective, touching on synthetic derivatives and the complexities of organic chemistry.
  • Some participants question whether adding an oxygen molecule to marijuana would alter its chemical properties, suggesting that oxidation could lead to the formation of different compounds.
  • Others explain that organic chemistry is complex, and simply adding elements is not straightforward, as it involves understanding molecular interactions and potential side effects.
  • A participant mentions that adding oxygen in atmospheric amounts could oxidize THC, complicating the outcome by producing multiple compounds rather than a single desired product.
  • One participant highlights that combustion of marijuana inherently involves oxidation, questioning the feasibility of adding oxygen without changing the chemical nature of the substance.
  • Another participant provides an example of how modifying ethanol by adding oxygen results in a toxic compound, indicating that changes can have significant effects.
  • There is a humorous remark about not adding "fire" to marijuana, emphasizing the harmful effects of smoke.
  • Links to external resources on synthetic cannabis are shared, suggesting that there are ongoing efforts to modify substances, albeit with regulatory challenges.
Participants express a range of views on the feasibility and implications of modifying illegal drugs. There is no consensus on whether such modifications can be made without significant changes to the chemical structure or effects.
Discussions include assumptions about chemical reactions and the complexity of organic chemistry, with some participants lacking a foundational understanding of the subject. The conversation remains exploratory without resolving the intricacies of chemical modifications.
This discussion may be of interest to individuals curious about organic chemistry, drug synthesis, and the implications of chemical modifications in pharmacology.
Black Hole
First off I am nothing of a scientist or chemist.
can you add a oxygen molecule to say marijuana without screwing it up?
or if i add one of the inert gases to it?
haha, I'm just thinking out loud
what you scientists say?
Chemistry news on Phys.org
I don't even know if this question can be salvaged into a reasonable topic, but I'll try (although I suspect that this topic is not allowed on these forums. I'll do my best to keep it professional):
Many natural products, such as cannabinoids and opioids, do have synthetic derivatives. In fact, the term "semi-synthetic" is often applied to these types of molecules. For example, morphine, extracted from poppy seeds, is used as a precursor in the industrial manufacture of hydromorphone.
However, it's much more complicated than just "adding oxygen" or "adding an inert gas" to the molecular structure. In fact, those terms are pretty meaningless--all reactions are organic reactions, and organic chemistry isn't as simple as adding A +B to make C. Of course, it becomes even more complicated in biological systems.
Deciding on an appropriate pharmaceutical derivative of a natural product is a complicated task: it involves first of all understanding how the original molecule interacts with different receptors in the body, the overall goal of the intended pharmaceutical, minimization of side effects and toxicity (relative to the intended dosage).
Overall, this is a cool field, but as you said, it's pretty clear you aren't a scientist or a chemist ;-)
Adding oxygen to THC in atmospheric amounts will oxidize a small amount of compound, which in this case means you are reacting the oxygen with the double bonds in the molecule, and this will likely wreck it as there is no easy way of going back from this. At higher amounts of oxygen, this "oxidation" rate increases. The other complication is that the oxygen will probably react with different double bonds at different rates so that you will not just get one compound but various percentages of 3-4 different compounds (given THC's benzene ring and double bond). Chemists usually don't like getting various compounds because you can't single out the "good one" among the "bad ones" without some major chemical wizardry, so most chemists will only add raw gasses to compounds that have blatantly electropositive molecules they know will produce only one compound; THC is not like that. Finally, adding an "inert gas" like Neon, Argon, Krypton, or preferably Nitrogen (which is not noble, but in its N2 form is relatively inert) due to its much lower cost, will do nothing to the molecule, but some food packagers use nitrogen precisely for its inertness as it displaces oxygen while packing and thus retards spoilage and maintains freshness.
When you smoke MJ, you are directly oxidizing it. IE adding oxygen to it. Thats how combustion works. So i don't believe you could "add" oxygen to it and still keep it the same chemical.
I have to ask what you mean by "adding" an element to it. Do you mean that the element bonds and creates another substance? Or do you mean that the elements just diffuses throughout the material without bonding or combusting or anything? (Like a sponge soaking up water)
hey, I'm talking about stuff i have no clue about and i thank you guys for the responses
i stumbled upon this
http://en.wikipedia.org/wiki/Synthetic_cannabis
http://www.npr.org/blogs/thetwo-way...bans-fake-pot-products-that-emulate-marijuana
looks like someone is kind of doing this, but of course the dea and whoever else won't allow this to fly...
was just curious, always been interested in the "synthesis" of stuff from other stuff,
i'm in over my head cause i have no basic understanding of chemistry, just learning as we go
Black Hole said:
can you add a oxygen molecule to (...) without screwing it up?
Take a good, old ethanol that people consume legally for recreational reasons. Add a single oxygen atom to it - and you end with ethylene glycol, syrupy, toxic liquid used as an antifreeze.
It is not always this way - in some cases effect of modifying the molecule is not that large. But it is always possible.
Whatever you do, don't add the element "fire" to that marijuana. The smoke is harmful and will screw you up!
Oh... :wink:
  • · Replies 130 ·
29K
  • · Replies 19 ·
11K
