GAIN and IMPEDANCE of a complex Circuit
The forum discussion centers on calculating the gain of a complex circuit using impedance (Z). The correct formula for Z is established as Z = [jwL + (R/jwC)]/(R + 1/jwC). The gain is defined as the ratio of output voltage to input voltage, with the output voltage represented as Vo * Zab/Z. The magnitude of the gain is determined by the ratio of Zab to Z, clarifying that Z represents impedance, not voltage.
  • Understanding of complex impedance in AC circuits
  • Familiarity with the concepts of voltage gain and output/input voltage ratios
  • Knowledge of circuit components such as resistors (R), inductors (L), and capacitors (C)
  • Proficiency in using complex numbers in electrical engineering calculations
  • Study the derivation of impedance in RLC circuits
  • Learn about calculating voltage gain in AC circuits
  • Explore the use of phasors in analyzing AC circuit behavior
  • Investigate the impact of frequency on impedance and gain in circuits
Electrical engineers, circuit designers, and students studying AC circuit analysis will benefit from this discussion, particularly those focused on gain calculations and impedance in complex circuits.
JamesJames
I am supposed to calculate the gain of the circuit given in the attachment. I have attached it in a word file.
Z is the generic term for the effective resistance. I get that Z is
Z = [jwL +(R/jwC)]/(R+1/jwC)
Can someone tell me if this is correct?
Also, now for the gain, it is supposed to output Voltage/input voltage. For this example, is Z the output voltage and jwL + Z the input voltage ?
James
To view the attachment, just click on it and say open.
Any help would be really useful.
Thanks, James
Zab=(R/jwC)/(R+1/jwC),
Z = [jwL +(R/jwC)/(R+1/jwC)]
GRRRRRR. Z is impedance, not voltage. The output voltage is Vo * Zab/Z. So the gain is the magnitude of Zab/Z.
ehild
  • · Replies 21 ·
