What Are the Differences Between Single Phase and Three Phase Power?
  • Thread starter Thread starter greatEE
    Phase Three phase
The discussion revolves around the differences between single phase and three phase power systems, focusing on their wiring, operational characteristics, and efficiency. Participants explore technical aspects, advantages, and challenges associated with each type of power supply, as well as implications for motor performance.
  • Some participants note that three phase motors can output more torque and are more efficient than single phase motors, likening the extra wires to having more pistons in an engine.
  • Others explain that single phase motors require a start winding circuit for initial torque, while three phase motors do not due to the inherent rotating field created by the three phases.
  • One participant mentions that three phase motors typically have a lower current draw per conductor compared to single phase motors, which can allow for smaller wiring in some cases.
  • Another point raised is that three phase systems provide a constant power supply, which can lead to greater capacity compared to single phase systems.
  • Concerns about the reliability of single phase motors are discussed, particularly regarding their ability to start and run without issues, as well as the potential for them to operate in reverse under certain conditions.
  • Some participants argue that three phase motors are generally cheaper to manufacture and longer-lasting than single phase motors.
  • There is a discussion about the implications of electrical supply generation, noting that three phase systems are designed to be more efficient due to their balanced loading and reduced need for a neutral wire.
Participants express a range of views on the efficiency and operational characteristics of single phase versus three phase motors, with no clear consensus on all points. Some argue for the advantages of three phase systems, while others highlight specific challenges or misconceptions about single phase systems.
Participants mention various technical details and assumptions about motor operation, wiring requirements, and efficiency that may not be universally applicable or may depend on specific contexts.
This discussion may be useful for individuals interested in electrical engineering, motor design, or those seeking to understand the practical differences between single phase and three phase power systems.
greatEE
what are the major different other than the reason why you do three phase for motor and advantages. In detail in wiring why do you have 4 lines in three phase goig into three terminal and 4 lines goign into two termnial in single phases?
what is the best way to give a summary to a person who doesn't know the difference? Like people who are not familiar with electrical stuff at all?
thanks in advance, i appreciate all your mega brainers help! =) :bugeye:
well, by no means am I a pro, but from what I understand a 3 phase motor outputs more torque. By having the extra wires your talking about, this is similar to having more pistons in an engine.
But they also require more energy to operate.
*single phase motors require 3 conductors 1/ a ground or bond (as in all motors for safety) 2/ two power conductors, or a power conductor and a neutral conductor [from a source: motor starter/motor switch (internal connections may be confusing you)].
a single phase motor requires a start winding circuit that gives initial torque and direction until the motor speed is such that the the rotating field of the run winding is stable enough to maintain the rated horse power of the motor, at which time the start winding is released by way (usually) of a centrifugal switch.
*a three phase motor requires 4 conductors 1/ a ground or bond (as in all motors for safety) 2/three power conductors each of course providing ac voltage, and each 120 degrees out of phase with each other [consider a complete circle as 360 degrees divided by three (it is more complicated than this but do your reading)](a y configured three phase service has the three conductors described herin plus a neutral that is never required in the operation of a three phase motor as in your question)
due to the fact that we are utilizing three voltages 120 degrees out of phase from each other, we can see that a rotating field is much more easily satisfied (one might say, we already inherently have it), and therefore do not require a start winding of any sort.
so, we place this rotating field around a big chunk of ferrous metal (much more complicated than this ie: windings, eddie currents, losses... do your reading!) and we get a more reliable (no contacts), better electrically balenced (cost efficient, no a to gnd) ... do your reading!
don rigby said:
... better electrically balenced ...
I think that implies it would also be better mechanically balanced?
"I think that implies it would also be better mechanically balanced?"
that would be a question better put to a motor manufacturer(obviously easier).
however, from what i have seen...i could send a block of wood to a good electric motor repair shop for rotational balencing (if they were given solid points of reference).balencing equipment today, leaves little to be desired under most common rpm requirements.
I wouldn't say a three phase motor requires more energy to operate. They are more efficient than single phase motors. They are typically lighter in weight per horsepower, cheaper to manufacture and longer lived. You can buy three phase motors of the same horsepower cheaper than single phase. The current draw on three phase motors per conductor is less than a single phase. In some cases you can use smaller wires feeding the motor with 3 phase compared to single phase because of this difference.
If you write out the three phase currents as explicit functions of time, Imaxcos ωt, Imaxcos (ωt - 120°) and Imaxcos (ωt + 120°), square them, multiply by the resistance R, and add, the result is the constant (3/2)Imax2R = 3 I2R. The power is applied steadily as in DC circuits, not in pulses as in single-phase AC circuits. This is a great advantage, giving three-phase machines 48% greater capacity than identical single-phase machines.
http://www.du.edu/~jcalvert/tech/threeph.htm
Note also that 3 phase allows for inherently reversible motors - reverse any two hot legs. Although there are single phase reversible motors as well now, they can get lost [out of phase] and go the wrong direction.
"In some cases you can use smaller wires feeding the motor with 3 phase compared to single phase because of this difference."
in all cases above 15 amps, by a factor of root 3. only because 15 amp wire is the smallest acceptable (except control wiring).
"Note also that 3 phase allows for inherently reversible motors - reverse any two hot legs. Although there are single phase reversible motors as well now, they can get lost [out of phase] and go the wrong direction."
i think what you meant to say is:
on a single phase motor, if the start circuit fails to a certian degree or completely, respectively, the motor will;
a/ either not come up to full rpm and then, thermal and/or over current protection opens the power circuit., or b/ just hum loudly until, thermal and/or over current protection opens the power circuit.
not to say that there wasn't ever a case in history where a single phase motor started in reverse rotation, but i doubt it. once wired, it is pretty much committed.
Your electrical supply is made using a generator which supplies 3 phases out of phase with each other by 120 degrees, because a motor turns electrical energy into mechanical energy its just simply putting it a generator working in reverse thus its not too expensive to manafacture 3 phase motors and because the 3 phases are 120 degree out of step with each other the motor can run from power up using the existing magnetic fields already out of step.
Single phase motors don't have a natural out of step phase angle on the supplies so just connecting it to single phase supply would just melt the internal wiring without the motor turning to achieve the out of phase magnetic field single phase motors require a out of step field generated from the one phase this can be achieved in various ways e.g. capacitor start motors but ultimately it adds cost to design and manufacture.
The main advantage of a 3 phase motor is its balanced loading over the three phase which means their is no need for a neutral and is cost effective to run compared to a single phase motor and due to the higher voltage used in comparison to a single phase you can have a smaller motor doing the same work load.
Thanks for the info', I am new to this site just finding my feet.
  • · Replies 19 ·
  • · Replies 41 ·
19K
