SU(n) - conjugate representation
The discussion centers on the properties of the SU(n) Lie algebra, specifically the relationship between the fundamental and conjugate representations. Participants explore the conditions under which these representations are equivalent, particularly focusing on the case of SU(3) and higher dimensions.
  • One participant notes that the generators of the SU(n) Lie algebra satisfy specific commutation relations and questions how to show algebraically that no transformation exists for n>2 that relates the conjugate representation to the fundamental representation.
  • Another participant explains that the fundamental and antifundamental representations are distinct due to their opposite complex structures, particularly highlighting the case for SU(2).
  • There is a discussion about the implications of eigenvalues and the requirement for them to come in pairs of opposite signs for a transformation S to exist.
  • One participant proposes that if a transformation S exists, it must map eigenvalues to eigenvalues, but the conjugate generators would map them to "minus eigenvalues," leading to a contradiction unless eigenvalues are paired.
  • Participants analyze the Gell-Mann matrices and note that for certain matrices, the eigenvalues do not come in pairs, which supports the claim that no such transformation S can exist for SU(3).
  • There is acknowledgment that the discussion has established a necessary condition for the equivalence of representations but has not proven sufficiency.
  • One participant introduces the concept of the \mathbb{Z}_2 outer automorphism of SU(n) to explain the inequivalence of the fundamental and antifundamental representations, particularly for SU(3).
Participants generally agree on the necessary condition for the equivalence of representations but do not reach a consensus on whether this condition is sufficient. There are competing views regarding the implications of eigenvalue pairing and the existence of transformation S.
The discussion highlights limitations in understanding the relationship between representations, particularly in terms of eigenvalue behavior and the implications of automorphisms in SU(n). Some assumptions about the nature of the representations and their eigenvalues remain unresolved.
tom.stoer
Very simple question, but I can't find the answer.
Taking an su(n) Lie algebra with hermitean generators we have
[tex][T^a, T^b] = if^{abc}T^c[/tex]
One immediately finds that the new generators
[tex]\tilde{T}^a = (-T^a)^\ast[/tex]
define the same algebra, i.e. fulfil the same commutation relations
[tex][\tilde{T}^a, \tilde{T}^b] = if^{abc}\tilde{T}^c[/tex]
One can show easily that for n=2 the two sets of generators are equivalent, i.e. related by a transformation
[tex]\tilde{T}^a = S T^a S^{-1}[/tex]
I know that for n>2 this is no longer true, i.e. that the two representations are not equivalent. That means that for n>2 this S cannot exist. My question is, how can one show algebraically that for n=3, 4, ... no S can exist such that
In general for [tex]su(n)[/tex] the fundamental representation [tex]V[/tex] and the antifundamental representation [tex]V^*=\text{Hom}(V,\mathbb{C})[/tex] are complex conjugate representations with opposite complex structures, so are distinct. In the case of [tex]su(2)= sl(2,\mathbb{R})[/tex] the fundamental representation is actually real, hence the equivalence you found.
Thanks; I know this. But what does it mean on the level of the matrices T and S? How can I show using simply the T's that the above mentioned S does not exist for su(n) with n>2.
You are requiring the representations to be real, if I am not mistaken. There was some requirement that the eigenvalues of the generators should come in pairs of opposite sign.
Again I know that, but why? Let's make a simple example. I give you the Gell-Mann matrices and let you calculate an S that does the job. Where do you fail to determine S? And why?
I think I figured it out.
One can check that iff S exists then it maps eigenvalues to eigenvalues. But using the conjugate generators one sees that it maps eigenvalues to "minus eigenvalues". These two mappings can only coincide iff the eigenvalues come in pairs.
One can check for the Gell-Mann matrices that for a=1..7 the eigenvalues come in pairs +1, -1. But for a=8 the eigenvalues are ~ 1, 1, -2 and are not paired. Therefore assuming S to do the job leads to a contradiction, whcih means that for SU(3) no such S can exist.
The characteristic polynomials for two similar matrices (meaning they are connected via [itex]B = S A S^{-1}[/itex]) are:
[tex] \mathrm{det} \left(B - \lambda \, 1 \right) = \mathrm{det} \left[ S (A - \lambda \, 1) S^{-1} \right] = \mathrm{det}{S} \, \mathrm{det}\left(A - \lambda 1\right) \, \mathrm{det}{S^{-1}} = \mathrm{det}\left(A - \lambda 1\right)[/tex]
the same, so you are right there.
Because the generators are hermitian, they have real eigenvalues. Thus, the eigenvalues of [itex]\tilde{T^{a}} = -(T^{a})^{\ast}[/itex] should be the set [itex]\{-\lambda^{\ast}\} = \{-\lambda\}[/itex].
True, however, we have just proven that the condition is a necessary one. I am not sure whether it is easy to show that it is a sufficient one as well, or even if that is true.
Yes, I wanted to reply to your first reply with the 8th Gell-Mann matrix, but you beat me to it. :smile:
Thanks for responsing and for LaTeX.
My original problem was to understand why the fundamental and the conjugate rep. of SU(3) are not equivalent. This is what we have solved now. I agree that we only discussed a necessary condition, we did not show whether it's suffcient.
The fundamental and antifundamental representations are related by the [tex]\mathbb{Z}_2[/tex] outer automorphism of [tex]SU(n)[/tex]. You can either see this from the weight diagram or by labeling the Dynkin diagram with the highest weights. This means that [tex]SU(n)[/tex] has inequivalent actions on them. For [tex]SU(2)[/tex], there are no outer automorphisms, so there was an inner automorphism that related the conjugate representations.
For [tex]SU(3)[/tex], what distinguishes the two representations is the choice of [tex]\lambda_{2,5,7}[/tex]. If we take these to be the fundamental representation, then the antifundamental matrices [tex]-\lambda_{2,5,7}[/tex] correspond to an inequivalent complex structure.
  • · Replies 27 ·
  • · Replies 0 ·
