New Reply
Finding position from velocity (trig function)
Share Thread
Mar2-11, 09:28 PM   #1
S(0)=3, find S(2) position wise.
2. Relevant equations
V(t)=xsin(x^2)
3. The attempt at a solution
I tried to integrate with u-substitution and I got -t^4/4cos(t^2). I tested it by taking the derivative and it didn't work out.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar2-11, 09:41 PM   #2
Mentor
[tex]v(t)=\frac{dx}{dt}\quad\to\quad\frac{dx}{x\sin(x^2)}=dt[/tex]
Is the equation on the right what you integrated?
Mar2-11, 09:46 PM   #3
@SammyS,
Thanks for the reply, but I have never seen the method you used before. I understand that you manipulated the first equation to get the second, but I do not know why. If you could explain it a bit or give me a link to a website that explains it I would appreciate it.
Mar2-11, 10:39 PM   #4
Recognitions:
Homework Helper Homework Help
Are you sure that your velocity function is v(t) = x*sin(x^2), where x is a distance? Is it possible that it's v(t) = t*sin(t^2) instead?
Mar2-11, 10:50 PM   #5
Mentor
If  [tex]\frac{dx}{dt}=x\sin(x^2)\,,[/tex]
then  [tex]\frac{1}{x\sin(x^2)}\ \frac{dx}{dt}\,dt=dt\,.[/tex]
But,  [tex]\frac{dx}{dt}\,dt=dx\,.[/tex]
Therefore,  [tex]\frac{dx}{x\sin(x^2 )}=dt[/tex]
Now integrate both sides to find t as a function of x.
Mar2-11, 10:53 PM   #6
Recognitions:
Quote by SammyS View Post
I think that the LHS is going to prove to be rather difficult to integrate in closed form.
Mar2-11, 11:05 PM   #7
Mentor
Quote by gneill View Post
Yes, I believe you are right about this.
Your earlier suggestion: [tex]v(t)=t\sin(t^2)[/tex] is probably correct.
Mar3-11, 12:17 AM   #8
I switched t with x in the equation. Now that I think about it I'm even unsure of why I did this. Anyway, I solved the problem by taking t out of the function before integrating. Thank you all for the quick replies.
New Reply
Similar discussions for: Finding position from velocity (trig function)
Thread Forum Replies
simple harmonic motion problem, finding velocity as a function of position Introductory Physics Homework 5
finding an expression for position from a velocity expressed as a function of positio Calculus & Beyond Homework 3
The position function from given velocity or acceleration function Calculus & Beyond Homework 3
Finding the Velocity from Acceleration as a function of position Calculus & Beyond Homework 8
Velocity as a Function of position Introductory Physics Homework 1
