Finding the Intersection Point of Two Lines in Vector Form
  • Context: Undergrad
  • Thread starter Thread starter ross
    Intersection Lines
This discussion focuses on finding the intersection point of two lines represented in vector form using the equation (x, y) = (start_x, start_y) + t((end_x, end_y) - (start_x, start_y)). The key insight is that the parameter "t" does not need to be the same for both lines at the intersection point. Instead, users should solve a 2x2 system of equations for the two parametrization variables, t¹ and t², or eliminate the parametrization to solve for x and y directly using linear equations. The final approach discussed involves converting the vector form into slope-intercept form (y = mx + b) to find the intersection.
  • Understanding of vector equations and parametrization
  • Familiarity with solving systems of linear equations
  • Knowledge of slope-intercept form of a line
  • Basic algebra skills for manipulating equations
  • Study how to solve 2x2 systems of equations using substitution and elimination methods
  • Learn about vector algebra and its applications in geometry
  • Explore the conversion between vector form and slope-intercept form of lines
  • Investigate the geometric interpretation of line intersections in a coordinate plane
Mathematicians, computer graphics developers, and anyone involved in computational geometry or physics simulations seeking to understand line intersections in vector form.
ross
I'm using the following equation to represent lines
I'm trying to find the interesection point of two lines written in this form.
I have been able to solve for t and plug it back into the equation, but i get two values of t when i solve for it. So that gives me 2 possible x values and 2 possible y values in the end. One x value is correct, and one y value is correct, but I get a wrong x value and a wrong y value.
I'm wondering if there's a totally different way, or a way to get rid of the x and y value that I don't need.
Thanks.
Welcome to PF!
You are going about this in a fundamentally wrong way.
The parameter "t" need not have the same value at the point of intersection for each line!
What you need, is to solve a 2*2 system of two unknowns, the two parametrization variables:
Let superscript "1" denote Line 1 expression, "2" Line 2 expression.
Then we may write:
[tex](x,y)=(x^{1}_{0},y^{1}_{0})+t^{1}(x_{1}^{1}-x_{0}^{1}, y_{1}^{1}-y_{0}^{1})[/tex]
And line 2:
[tex](x,y)=(x^{2}_{0},y^{2}_{0})+t^{2}(x_{1}^{2}-x_{0}^{2}, y_{1}^{2}-y_{0}^{2})[/tex]
Set these expressions equal to each other, and solve for [tex]t^{1},t^{2}[/tex]
You may also eliminate the parametrization variable, and solve the following system
for x and y:
[tex]y=a^{1}x+b^{1}[/tex]
[tex]y=a^{2}x+b^{2}[/tex]
Ok, thanks.
What I ended up doing was turning the (x, y) = (a, b) + t(c - a, d - b) into y = mx + b. Then I solved for x and y.
The reason I wanted t was to know whether the intersection was actually between the two points (0 <= t <= 1). But I can just plug the point I found back into the first equation and solve for t.
x = a + t(c - a)
t = (x - a) / (c - a)
  • · Replies 17 ·
  • · Replies 17 ·
