Can the Frequency of Oscillations Measure Fluid Density in a Loaded Test Tube?
The discussion revolves around the feasibility of using the frequency of oscillation of a loaded test tube floating in a fluid to measure the fluid's density. The problem is situated within the context of oscillations and waves.
  • Participants explore the relationship between the oscillation frequency and fluid density, questioning whether the motion can be classified as simple harmonic. There are discussions on the forces acting on the test tube and how they relate to the oscillatory motion.
The discussion is active, with participants offering insights into the forces involved and their implications for the motion of the test tube. Some guidance has been provided regarding the nature of the motion, but there is no explicit consensus on the assumptions being made.
Participants are considering the effects of damping due to fluid resistance and the linear relationship between the volume of displaced water and the depth of immersion, which may influence their understanding of the oscillatory behavior.
garytse86
I am stuck in this question:
A loaded test tube of mass m is floating in a fluid. The test tube has a cross-sectional area A and fluid has density p.
Comment on the feasibility of using the frequency of oscillation of the tube to measure the density of the fluid.
I would say this is feasible because although there is damping due to resistance of the fluid, the frequency is the same because the motion is simple harmonic, is this correct?
Thanks.
How do you know the motion is simple harmonic? :-)
well this is under the section oscillations and waves, so should I state the assumption is that the motion is simple harmonic?
You don't have to assume. You can show it!
Basically, two forces act on the test tube, the gravitational force which doesnt' change and the buoyant force which depends on the volume of the water displaced by the test tube. Since the test tube has a uniform cross section the volume of water displaced varies linearly with the depth of the test tube's immersion into the water. Therefore, the motion will be simple harmonic!
oh right, thanks very much!
