Help With a Frictionless Ramp and Physics Concepts
  • Thread starter Thread starter butz3
The discussion focuses on solving a physics problem involving a cart moving up a frictionless ramp inclined at 10 degrees with an initial velocity of 8 m/s. The key solution involves using the conservation of energy principle, leading to the conclusion that the cart will ascend to a height of 3.27 meters. Additionally, the user seeks clarification on concepts such as negative potential energy, zero kinetic energy, mechanical work in non-isolated systems, and thermal energy, demonstrating a solid understanding of basic physics principles.
  • Understanding of conservation of energy in physics
  • Familiarity with basic kinematic equations
  • Knowledge of gravitational acceleration (g = 9.8 m/s²)
  • Concept of potential and kinetic energy
  • Explore the derivation of energy conservation equations in frictionless systems
  • Study the implications of inclined planes on motion and energy
  • Learn about different types of energy systems, including isolated and non-isolated systems
  • Investigate real-world applications of thermal energy and molecular motion
Students learning physics, educators teaching energy concepts, and anyone interested in understanding motion on inclined planes and energy conservation principles.
butz3
i'm not sure how to begin this problem. "a cart that is moving at 8:00m/s heads up a frictionless ramp inclined 10.0 degrees from the horizontal. how far up the ramp should it go?" also i want to know if I'm on the right track with this question "give an example of each of the following objects or systems. a) and object with a negative potential enery. " i said an object at rest. b) " an object with zero kinetic energy" i said a ball stopped in a catchers mitt. c) a system that does mechanical work and loses energy. i said an open , non isolated system. and d) themal energy being produced by a system. i said a can of pop on a beach, fast moving molecules. any help would be great as I'm trying to teach my self. its kind of hard thanks
1/2mv^2 = mgsinxd
1/2v^2 = gsinxd
d = v^2/2gsinx
That is one way you can solve it. There is probably more than one way.
I might have screwed up though, who knows. In fact I probably did. I'm going to try and do it another way.
Here's another way, easier I guess:
a = gsinx (it's going up at a ten degree angle, so the component of gravity is gsinx)
v^2 = 2ad
d = v^2/2gsinx
Same thing. Guess I was right after initially screwing up sines and cosines. It happens to the best of us.
For the first problem, it is important to understand the basic physics concepts involved. The key concept here is conservation of energy. In a frictionless system, the total energy (kinetic + potential) remains constant. Therefore, you can use the equation: E = mgh + 1/2mv^2, where E is the total energy, m is the mass of the cart, g is the acceleration due to gravity, h is the height of the ramp, and v is the velocity of the cart. Since the cart starts with a velocity of 8m/s and reaches a height of h, we can set the initial energy equal to the final energy and solve for h. So, 1/2mv^2 = mgh, which simplifies to h = v^2/2g. Plugging in the values, we get h = (8m/s)^2/(2*9.8m/s^2) = 3.27m. Therefore, the cart should go up the ramp for a distance of 3.27 meters.
For the second part, your answers seem to be on the right track. An object at rest has a negative potential energy because it has the potential to move downwards due to gravity. A ball stopped in a catcher's mitt has zero kinetic energy because it is not in motion. An open, non-isolated system can do mechanical work and lose energy because it can exchange energy with its surroundings. And a can of pop on a beach with fast-moving molecules is a good example of thermal energy being produced by a system. Keep up the good work in teaching yourself and continue to practice solving problems to improve your understanding of physics concepts.
  • · Replies 32 ·
