Help: Solve Kinetic Energy of Pushing Piano up an Incline
The discussion revolves around calculating the kinetic energy of a piano being pushed up an incline. The problem involves a mass of 328.4 kg, an incline of 9.1 degrees, and a force of 722.1 Newtons applied parallel to the incline.
  • Participants discuss the application of Newton's second law and the forces acting on the piano, including gravity and the applied force. There are attempts to calculate acceleration and subsequently kinetic energy using different methods.
Multiple participants are exploring different calculations and methods to arrive at the kinetic energy. There is acknowledgment of discrepancies in results, with some suggesting that rounding may be a factor, while others assert that their calculations were done without rounding.
Participants are working under the assumption that all contacts are smooth and are questioning the accuracy of their calculations based on the provided values and forces.
buffgilville
A mover is pushing a piano whose mass is 328.4 kg up a plane that is inclined 9.1 degrees to the horzontal. The force of 722.1 Newtons is applied parallel to the incline, whose length is 7.4 meters. Assuming that all contacts are smooth, find the kinetic energy of the piano at the end (in Joules).
F=ma
722.1cos9.1 x + 722.1sin9.1 y = 328.4a x
a = 2.17
vsquared = initial vsquared +2ax
v = 5.67 m/s
K=(1/2)mvsquared
K= 5278.85 joules
but the correct answer is 1574.97 joules. Can someone please tell me what I did wrong?
Try to draw a free body diagram. In one direction, you have 722.1 Newtons acting on the piano. In the opposing direction, you have the force of gravity.
F = ma
Mover's force - force of gravity (sin 9.1 * mg) = Net Force
Acceleration = Net Force/Mass
...with this acceleration, just use the same method you had above to find Kinetic Energy.
thermodynamicaldude, I tried your method, but I got 1573.07 joules. The answer is 1574.97 joules.
722.1 - 509.52 = 212.58
212.58/328.4 = 0.647
v = 9.5756
k = 1573.07
The process seems right. The error may just be because of rounding.
no, it can't be because of rounding because I calculated it straight through without rounding.
So did I, but I got a slightly different answer. Which wasn't the same as yours or what it should be.
13K
