Total Kinetic Energy B/F & A/F Collision
The discussion focuses on calculating the total kinetic energy before and after a collision involving a truck and a car. The truck, with a mass of 3000 kg, initially travels at 5.0 m/s, while the car moves at 2.0 m/s. Post-collision, the truck's velocity is 3 m/s and the car's is 6 m/s. The kinetic energy formula, KE = 1/2 mv², is essential for this calculation, and the mass of the car must be determined using conservation laws.
  • Understanding of kinetic energy formula (KE = 1/2 mv²)
  • Basic knowledge of momentum conservation principles
  • Ability to perform algebraic calculations
  • Familiarity with units of mass and velocity
  • Calculate the total kinetic energy before the collision using the given velocities.
  • Determine the mass of the car using conservation of momentum.
  • Calculate the total kinetic energy after the collision with the new velocities.
  • Compare the total kinetic energy before and after the collision to analyze energy loss.
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators seeking to explain kinetic energy and momentum conservation principles.
iNarb
The truck of mass 3000Kg, moving at 5.0m/s on a level on a level, icy road, bumps into the rear of a car moving at 2.0m/s in the same direction. After the impact the truck has a velocity of 3m/s and the car a velocity of 6m/s both forward. Calculate the total kinetic energy before and after the collisioin
Dont know the equation
Well, the equation for kinetic energy is 1/2 mv^2.
This is a relatively simple equation to use; for total kinetic energy you must calculate the KE for each body involved.
However, since in this problem the mass of the car isn't given, you'll probably have to find that first (hint: what conservation law involves mass and velocity?).
Hope this helps!
  • · Replies 22 ·
