Ultimate size of the Universe (finite)
  • Context: Graduate
  • Thread starter Thread starter AJustice
    Finite Universe
The discussion revolves around the concept of the ultimate size of the universe, particularly in the context of gravitational interactions between two hypothetical particles. Participants explore the implications of gravitational energy, kinetic energy, and relativistic effects on the maximum separation distance of these particles, considering both theoretical and conceptual frameworks.
  • One participant argues that if two lightest particles are considered, the universe must have a maximum size due to the balance of potential gravitational energy and kinetic energy as they approach light speed.
  • Another participant questions the feasibility of defining a maximum kinetic energy for particles moving near light speed, suggesting that it can always be increased without bound.
  • A different viewpoint introduces the idea of the universe having critical density and compares it to a black hole scenario, noting that predictions about the universe's size cannot be made based on kinetic energy derived from distances beyond the observable universe.
  • Concerns are raised about the assumptions regarding the nature of the universe and the implications of using a flat Minkowski metric for the discussion of gravitational interactions.
  • Some participants highlight the importance of understanding the relativistic kinetic energy formula, emphasizing that it diverges as velocity approaches light speed, which complicates the argument about maximum energy limits.
  • There is a discussion about the gravitational force between particles increasing as they approach each other, suggesting that energy is stored in the separation distance, albeit diminishing with distance.
Participants express differing views on the implications of gravitational and kinetic energy in relation to the universe's size. There is no consensus on the validity of the initial argument or the assumptions made, indicating that multiple competing views remain unresolved.
Limitations include the dependence on specific definitions of particles and the universe, as well as unresolved mathematical interpretations of energy relationships in relativistic contexts.
He is right
  • probably missing something
    Votes: 0 0.0%
  • makes sense, he is a genius
    Votes: 0 0.0%
  • I don't know
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
AJustice
Ok, I am a mechanical guy, mechanical engineering degree. With an argument with my Engineering physics wife.
1. Imagine 2 particles (lightest particle with any finite mass)
2. separated by the the entire distance of the universe
3. the particles are attracted (due to gravity) to each other and will require an infinite amount of energy to reach full "light speed"
The particles will accelerate (increase mass due to relativity) as they move toward another and speed up. This will require an infinite amount of energy.
So, I say that if we assume the entire Universe is reduced to two "lightest" particles, the Universe MUST have a MAXIMUM size because two of the lightest particles must have a maximum distance where the POTENTIAL GRAVITATIONAL energy equals the kinetic energy of two lightest particles at near "c". and our "real" universe is smaller because I know more than 2 particles exist...\
Do you agree, or am I missing something?
What to you mean the "kinetic energy of two lightest particles at near c"? How near, exactly? No matter how large a finite energy E you choose, that will always be equal to the kinetic energy of the particles at some velocity v less than c, so it will always be possible to imagine the particles moving at a velocity less than c but larger than v where their kinetic energy would be greater than E. So, it's impossible to find any finite upper limit on the amount of kinetic energy those particles could have with a velocity sufficiently close to c.
A similar circumstance arises If the universe is considered to have critical density, and you imagine it is a black hole with all the matter concentrated at the Hubble center, a particle ejected from the concentrated center at a velocity approacing c would have zero velocity as it exited the observable universe - but this doesn't provide any information about the size of the universe beyond the Hubble sphere - the same is true working the dynamics in reverse - you cannot make any meaningful predicitions about the size of universe based upon KE derived from distances beyond the Hubble sphere
How do you figure? Are you getting this from a source or is it your own argument?
AJustice said:
..1. Imagine 2 particles (lightest particle with any finite mass)
Why 'lightest particle with mass' (presumably a neutrino)? How does this effect the argument?
What kind of 'universe' exactly? I'm guessing you are thinking of a flat Minkowski metric upon which these two particles just sit. Is that true? I have no idea what a 'universe' of two particles governed by GTR would look like, but nothing like the one we inhabit I would say!
Sure, but where would the energy come from? Since the total initial energy of this system (two lightest particles at 'infinite' separation) is just 2*mc2 (m being the mass of each 'lightest particle'), then by the conservation of energy all that can change as distance decreases is an exchange between potential and KE, the total remaining constant. you are I assume aware that as a classical force, gravitational attraction drops off as the inverse square of separation distance.
As per 3 above, how so? I suspect you are picturing a constant force of gravitational attraction independent of separation, which is far from true.
A lot I would say. Clarify points 1-3 and your strange (to me at least) reasoning above should change somewhat!
Hi AJustice, welcome to PF! Unfortunately for your analysis, the kinetic energy of a particle at near c is unbounded.
Re: your argument with your wife. I can't believe that you would argue with your wife about this kind of stuff. IMO, you really need to learn to pick your battles! Make sure you score some points losing this one.
Point 1 (particle must have mass so the kinetic energy formula isn't equal to zero
Point 2 "The universe is in this case a large 3d volume that has a limited diameter equal to the distance of these two "lightest" particles at their maximum separation
Point 3 Yes, I understand that gravity drops off... But, it never fades to zero. So, maybe the first 4 lightyears of separation stores 3MJ of potential energy and the next 4 light years only stores 0.0003MJ. BUT, there is still energy stored by seperating two particles by a distance. ALSO, if I remember correctly, as the particles head towards one another, (approaching the speed of light), the gravitational force between the two increases. (their gravity, not mass, increases)
So, the point is, no matter how infinitely small, a near infinite (but finite) distance will store a tremendous amount of energy.
If I take two particles I CANNOT separate them by a distance that would equate to a potential energy greater than the maximum kinetic energy (both particles at the speed of light)
Is the source of your confusion that you think the Newtonian formula for kinetic energy ½mv2 applies here? It doesn't. The relativistic formula for kinetic energy is
[tex]\left( \frac{1}{\sqrt{1-v^2/c^2}}-1\right) mc^2[/tex]​
If you try to put v=c and m>0 in that, you get ∞, which is the mathematics telling you that you've tried to do something impossible. In particular, for a given fixed m, there is no maximum value to the expression; you can make it as large as you like.
DrGreg, I think I am arguing the opposite side of the same coin. I am saying since there it would take an infinite amount of energy to reach "C" (you can't ever do it) then if we go to .9999999999999999999999999c work the equation equal to the potential energy equation... you should have the size of the universe (since a lot of energy is tied up in the other REAL masses that we know exist the .99999...should be a reasonable estimate)
Why should the size of the universe be the distance where the gravitational potential is equal to the kinetic energy at .9999999999999999999999999c? This energy would be very small compared to the kinetic energy at .999999999999999999999999999999999999999999999999c for example, which itself would be very small compared to the kinetic energy at an even larger fraction of c, etc.
The point is, by picking larger and larger fractions of light speed you get larger and larger values of the kinetic energy of a given particle at that speed, with no upper limit. And thus there is no upper limit on the distance at which the gravitational potential is equal to kinetic energy at an arbitrarily large fraction of light speed. For any distance you can think of, if you calculate the potential energy between two particles at that distance, I can come up with a speed such that the kinetic energy of the particles at my chosen speed will be 10000 times larger.
The idea isn't to come up with a value, but a thought system that shows that unless there is an infinite amount of energy, then the universe MUST be finite.
In a universe with an infinite amount of matter (which is what is usually meant by an "infinite universe"), the energy would be infinite too, that just follows from E=mc^2.
AJustice, your argument is wrong. There is no maximum ke, therefore the size cannot be constrained by a nonexistent maximum ke.
It seems to me a really basic misunderstanding of the original post is that two particles at 'infinity' will gain infinite energy by the time they eventually collide, infinitely later. Instead, assuming e.g. baseballs, they will have an extremely small amount of energy, based the mutual escape velocity of two baseballs. If elementary particles, you've got to bring quantum mechanics into the picture (a zero radius particle of nonzero mass is a classical contradiction). They would interact with either in various ways long before any possibility of infinite density; and if you assume non-zero radius, then, even without quantum mechanics you just have the baseball scenario.
Thus the whole construction is simply wrong from the start.
Use the relationship [GM/R(c^2)] = 1 within the limits of experimental error
That doesn't really help explain much of anything you said, you'll need to provide a more detailed explanation of the various statements you made in that previous post. First of all, is that equation supposed to be the relationship between R and M for the Schwarzschild radius? If so it's not right, it should be [GM/R(c^2)] = 1/2. But what does this have to do with the rest of your statements? Are you saying that the radius of the observable universe is similar to the Schwarzschild radius of the mass contained in it? Even if this were true it would not make the universe a black hole, see the first section here. And even if we were in a universe-sized black hole, it would not make sense to say "a particle ejected from the concentrated center at a velocity approacing c would have zero velocity as it exited the observable universe" since it's impossible for anything to move in the outward direction once inside a black hole (it could move outward if the universe were a white hole, a possibility also discussed in the FAQ link above, but even in that case I don't understand where you would get the idea that a particle ejected from the central singularity "at a velocity approaching c" would "have zero velocity" as it passed outward through the event horizon).
  • · Replies 47 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 23 ·
