Calc Average Total Force for 50kg Cyclist on 1km Hill
  • Thread starter Thread starter jenc305
    Average Force
The discussion revolves around calculating the average total force required for a 50kg cyclist to ascend a 1 km hill while maintaining a constant speed. The problem involves concepts from physics, particularly forces, gravity, and motion.
  • Participants explore the need to calculate acceleration and question the implications of uniform speed. There are discussions about the forces acting on the cyclist, including gravity and potential friction, as well as the interpretation of the hill's height.
The conversation is ongoing, with participants offering different interpretations of the problem's parameters. Some suggest focusing on gravitational forces, while others emphasize the need for clarification on the problem's formulation. Guidance has been provided regarding the forces to consider, but no consensus has been reached.
There is uncertainty regarding the hill's height versus distance and the absence of information about friction. Participants express the need for clarification from the instructor regarding the problem's setup.
jenc305
How do I go about solving this equation. Thanks.
A 50kg cyclist, pedaling at 20 km/hr = 5.56m/s, climbs a 1 km hill in 30mins (.556m/s). What average total force on her bicycle is required for her to make it up the hill in this amount of time?
I know that I have to find the acceleration to calculate the force, since N=(kg*m)/s^2. What equation would I use to accomplish this?
I think you left something out of the statement of the problem. Given the information you provided the cyclist could just as well be coasting on level ground without expending any energy.
As the speed is uniform how could acceleration be there.
Force required to make it up the hill is equal to the force to overcome friction, if mentioned, work done against the gravity.
{i am not 100% sure but most probably it's true}
Interesting...that is all the information I was given.
So I wouldn't calculate acceleration since the cyclist is working against gravity.
If I used f=mg (g=-9.8m/s^2)would that determine the total force?
Oh, the "1 km" hill must refer to the HEIGHT of the hill! If that's the case then you can do it! Basically, how much energy is required to raise the cyclist through 1 km?
ooh..ok
So I would use the pythagorean theorem to find the angle and then use equation a=g sin (theta). Once I have found "a" then I can calculate f=ma.
Am I on the right track?
Thanks!
This question is poorly formulated. Since the bike is not accelerating, the total force on it must be zero. But I'm guessing that they want you to figure out the frictional force parallel to the hill that the ground must exert on the bike tires to overcome gravity. Find the angle of the hill and the component of the weight down the hill. That's what the friction must overcome.
You may want to ask your instructor for clarification.
9K
