Concepts of a Piston cylinder device
The discussion revolves around a piston-cylinder device containing 5 kg of water at 100°C with a quality of x = 20%. The external pressure is set at 100 kPa, and the piston mass is 75 kg with a cylinder area of 24.5 cm², which refers to the piston area. The user seeks clarification on whether the process occurs at constant pressure and how to calculate the initial volume, final pressure, work, and heat transfer terms while illustrating the process on a P–v diagram. The consensus is that the process can be assumed to occur at constant pressure due to the piston mass and external conditions.
  • Understanding of thermodynamic principles, specifically related to piston-cylinder devices.
  • Familiarity with the concepts of saturated vapor and quality in thermodynamics.
  • Knowledge of pressure-volume (P–v) diagrams and their significance in thermodynamic processes.
  • Basic calculations involving work and heat transfer in closed systems.
  • Study the principles of constant pressure processes in thermodynamics.
  • Learn how to calculate work done by a piston-cylinder arrangement.
  • Explore the use of P–v diagrams to represent thermodynamic processes.
  • Investigate the properties of saturated water and steam using steam tables.
Students and professionals in mechanical engineering, thermodynamics enthusiasts, and anyone involved in the design or analysis of piston-cylinder systems.
Xyius
3.A cylinder/piston arrangement contains 5 kg of water at 100°C with x = 20% and the piston, mP = 75 kg, resting on some stops. The outside pressure is 100 kPa, and the cylinder area is A = 24.5 cm2. Heat is now added until the water reaches a saturated vapor state. Find the initial volume, final pressure, work and heat transfer terms and show the process on a P–v diagram.
At this point I really only need help with the concept behind the problem. Is it correct of me to assume the process is happening in constant pressure? I am unsure because the mass of the piston is given and I am assuming that the heavier the piston the higher the pressure below it.
Also he gives me the area of the cylinder, do you think he meant the area of the piston? Because I do not know what he means by the area of the cylinder. Would that include the piston bottom as one of the caps on the cylinder?
Thanks
I emailed him, he did mean piston area. Although I am still unsure whether or not this would be constant pressure or not..
