Find the derivative of f(x) = (x-1)^(2/3) using the definition and then rules.
The derivative of the function f(x) = (x-1)^(2/3) can be accurately calculated using the alternate limit form, yielding f'(1) = 1/(x-1)^(2/3). The multiplication rule for derivatives, expressed as (u*v)'(x) = u'v + uv', was misapplied in the initial attempts, leading to incorrect results. The correct application of the exponent rule results in f'(x) = (2/3)(x - 1)^(-1/3). Understanding the distinction between evaluating derivatives at a specific point and the general derivative is crucial for accurate calculations.
  • Understanding of calculus concepts, specifically derivatives
  • Familiarity with the multiplication rule for derivatives
  • Knowledge of the alternate limit form for calculating derivatives
  • Proficiency in applying the power rule for differentiation
  • Study the application of the alternate limit form in derivative calculations
  • Review the multiplication rule for derivatives in detail
  • Practice problems involving the power rule for differentiation
  • Explore the implications of evaluating derivatives at specific points versus general forms
Students studying calculus, particularly those learning about derivatives, as well as educators seeking to clarify concepts related to differentiation rules and their applications.
PuddySporty
f(x) = (x-1) 2/3
We were asked to find the derivative using the alternate limit form when c = 1 and then I was then I was trying to find the derivative using the multiplication rule (u dv + v du).
f'(u*v) = u dv + v du
f'(xn) = nxn-1
When I did this, I got (2(x-1)-1/3)/3 which doesn't match the correct answer I got when I used the alternate limit form: 1/(x-1)^(2/3)
My question is if you can use the exponent rule on a polynomial and why it's not working out to be the same thing. Also, if you use the alternate limit form, does that mean it's the derivative for that c value only?
PuddySporty said:
f(x) = (x-1) 2/3
f'(xn) = nxn-1
Your equations here are incorrect. The frist one should be (f * g)'(x) = f'(x) g(x) + f(x) g'(x)
or
d/dx(u v) = u dv/dx + v du/dx
The second one should be d/dx(xn) = nxn - 1
The notation f' (something) does not mean "take the derivative of something," which is what you seem to think it means. Instead, it means "the derivative of f, evaluated at something."
If f(x) = (x - 1)2/3, then f'(x) = 1/(x-1)^(2/3) is incorrect. The first answer you showed is correct. Another way to write it is (2/3)(x - 1)-1/3.
