Are there degrees of quantum entanglement?
The discussion centers around the concept of degrees of quantum entanglement, exploring whether entangled particles can retain some level of entanglement after interacting with other particles. Participants also consider the implications of entanglement on seemingly random phenomena, such as photon emission and radioactive decay, and touch on the relationship between entanglement and higher-dimensional theories.
  • Some participants propose that there are degrees of quantum entanglement, suggesting that entangled particles may become less entangled after interactions with other particles.
  • Others argue that entanglement can be measured using concepts like von Neumann entropy and the purity of particles in an entangled pair.
  • A participant mentions the idea of "Entangled Entanglement," where a particle is entangled with a system of particles that is itself entangled.
  • There are questions about how entanglement might relate to the weak force and whether random phenomena can be explained by entanglement.
  • Some participants discuss the implications of entanglement in the context of higher dimensions, suggesting that entangled particles might be adjacent in a higher-dimensional space.
  • Concerns are raised about the potential for faster-than-light (FTL) communication, with a participant noting that quantum mechanics does not support such signaling despite the nonlocal nature of entanglement.
Participants generally agree that there are degrees of quantum entanglement, but multiple competing views remain regarding the implications of entanglement, its measurement, and its relationship to higher dimensions and FTL communication. The discussion remains unresolved on several points, particularly concerning the nature of entanglement and its effects.
Some claims about the measurement of entanglement and its implications depend on specific definitions and interpretations of quantum mechanics, which are not universally accepted. The relationship between entanglement and random phenomena is also not clearly established.
CosmicVoyager
Greetings,
Are there degrees of quantum entanglement? After entangled particles interact with others particles do they continue to be entangled to some degree? Becoming less entangled the more interactions that occur? So that there is complex network of entanglements?
If so, could it be that seemingly random phenomena such as when an electron emits a photon and radioactive decay be determined by quantum entanglements?
Thanks
CosmicVoyager said:
Greetings,
Thanks
There are a lot of unknown questions about entanglement. Many cases are nearly impossible to determine by experiment because the effects are too subtle to observe. I would say that the general theoretical answer is:
a) There are definitely degrees of quantum entanglement for a pair of entangled particles. For example: momentum position entanglement with OR without spin entanglement.
b) Conceptually, any number of particles can be entangled.
c) There is even something called Entangled Entanglement. A particle is entangled with a system of particles, which is itself entangled.
Presumably, entanglement could occur with the weak force as well. Not sure how that would work. I am not sure that random phenomena are ever "explained" by entanglement. But maybe that would become clearer at a certain point.
CosmicVoyager said:
Greetings,
Thanks
Yes indeed, there are degrees of entanglement. There are even measures of how entangled these particles are, such as the von neumann entropy, and the purity of a single particle in an entangled pair of particles, or the amount of violation of some Bell's inequality.
Entanglement between particles are also generally made using interactions. For example, say you have two non entangled particles and you would like to create entanglemend between them. One way to do is to make them interact with each other, for example, magnetic magnetic interaction from the spins of particles. Such interactions generally create an entangled system. In fact, when systems are interacting with each other, they are (usually) found in some entangled state. So one of the open questions in physics is: macroscopic objects are generally interacting with the environment all the time, so why is it that the macroscopic world do not display features of an entangled state?
Please take a moment to answer a newbie question.
My understanding of quantum entanglement is that a pair of particles can instantaneously interact even if they are separated by great distances.
But doesn't this just mean that even though they may be separated in our 4D spacetime, they may be adjacent (or even coincident) in another dimension? I thought that string and brane theories postulated 11 or more dimensions. Maybe entangled particles occupy or comprise the same string? It seems to me that quantum entanglement is a way for us 4 dimensional creatures to observe higher dimensions.
And if this turns out to be true, could it not open the door to the possibility of instantaneous long-distance communications?
Well, yes and no, we are now getting into some semantic and philosophical difficulties.
If is fine to think of quantum spacetime as being nonlocal in the manner you describe (adjacent or coincident). But you can't then twist that description to something that the math does not support. There are a number of theorems that explain/prove that QM does not support FTL signaling.
So you might be correct if QM is wrong. :smile:
  • · Replies 58 ·
  • · Replies 41 ·
