Harmonic Oscillator Expectation Values
The discussion focuses on calculating the time-dependent expectation values and
for a particle in a harmonic oscillator potential described by the wave packet |\Psi (x,t)|^2 = \left(\frac{m\omega}{\pi\hbar}\right)^{1/2}\textrm{exp}\left[-\frac{mw}{\hbar}(x - a\textrm{cos}\omega t)^2\right]. Participants suggest using Ehrenfest's theorem and raising/lowering operators to simplify the calculations. The integral for is identified as complex, with participants discussing substitution methods to evaluate it effectively.
  • Understanding of harmonic oscillator potential in quantum mechanics
  • Familiarity with wave functions and probability densities
  • Knowledge of Ehrenfest's theorem
  • Experience with integration techniques in quantum mechanics
  • Study the application of Ehrenfest's theorem in quantum mechanics
  • Learn about raising and lowering operators in quantum harmonic oscillators
  • Practice evaluating integrals involving Gaussian functions
  • Explore the properties of Hermite polynomials and their role in quantum states
Students of quantum mechanics, physicists working with harmonic oscillators, and anyone interested in calculating expectation values in quantum systems.
zje
A particle of mass m that is confined to a harmonic oscillator potential [tex]V(x) = \frac{1}{2} m \omega^2 x^2[/tex] is described by a wave packet having the probability density,
[tex]|\Psi (x,t) |^2 = \left(\frac{m\omega}{\pi\hbar} \right )^{1/2}\textrm{exp}\left[-\frac{mw}{\hbar}(x - a\textrm{cos}\omega t)^2 \right ][/tex]
where [tex]\omega[/tex] is a constant angular frequency and a is a positive real constant.
Calculate the time-dependent expectation values <x> and <p>. [Hint: Use Ehrenfest's theorem]
d<x>/dt = <p/m>
I'm not quite sure where to begin attacking this problem. I feel that if I can calculate <x>, then <p> should be easy given the equation above. I was thinking of trying the raising/lowering operators. Can I assume the particle is in the ground state since the only Hermite polynomial in [tex]\Psi[/tex] is [tex]H_0[/tex] = 1? Is there an easier approach to this problem? I tried just calculating <x> using
[tex]\int \limits_{-\infty}^{\infty} \Psi(x,t)x\Psi^*(x,t)\textrm{d}x[/tex]
but that was getting out of control fairly quickly.
That integral is pretty straightforward to do with a simple substitution. What did you try?
I tried expanding the exponent term and couldn't find a way to integrate by parts that made it simpler. Looking at it again, would the simple substitution be u=(x - a*cos[wt]), du=dx?
Thanks for your reply!
  • · Replies 16 ·
